gday all,
was just wondering what people would recommend for lubricating hinges and window winders and door lock mechanism?
Steve
Lubrication for Hinges, winders etc
_73LJWhiteSL_
, Jul 22 2006 05:18 PM
10 replies to this topic
#1 _73LJWhiteSL_
Posted 22 July 2006 - 05:18 PM
Posted 22 July 2006 - 07:10 PM
wd40
#3 _Herne_
Posted 22 July 2006 - 07:21 PM
Silicone spray.
Herne
Herne
#4 _gtr161s_
Posted 22 July 2006 - 07:43 PM
A lubricate called "never seize"
Its copper based grease and works like the name says.
#5 _Yella SLuR_
Posted 22 July 2006 - 08:18 PM
Hinges and lock, white grease pencil. Lock cylinder --> graphite. Window winder mechanism, white grease pencil, rubber guide tracks, silicon spray.
#6 _73LJWhiteSL_
Posted 23 July 2006 - 01:36 PM
Thanks for the suggestions people.
Steve
Steve
#7 _Loki_
Posted 23 July 2006 - 02:05 PM
WD40 Evaporates and dries up leaving you at square one again.wd40
Silicone based spray should work tops.
Posted 23 July 2006 - 06:42 PM
I believe the white grease pencils to which yella refers above are lithium grease which is what I would be using.
M@
M@
#9 _Yella SLuR_
Posted 23 July 2006 - 07:10 PM
Yeah, I'll have a look at it Mat. Somebody said that's what you use, so that's what I bought. Will have a look at the label and get back to you.
#10 _timbotorrie_
viscotene works well too!
#11 _Yella SLuR_
Posted 23 July 2006 - 07:21 PM
Goss Dri-Lube is what I have --> White grease pencil.
As with all things lubricant or adhesive wise, bugger all info that I can find on it.
