400 chev in lx torana engineering
63 replies to this topic
#51 _moot_
_moot_
Posted 23 January 2015 - 07:30 PM
As many people are aware, the NSW rules for vehicle modifications no longer have a "capacity limit" that cannot be exceeded. Basically, the bigger the engine the more has to be done to prove that the rest of the vehicle (chassis strength, driveline, brakes, suspension, handling etc can handle the weight, torque and power of the engine. That means, for example, an early Holden, Torana, Cortina, Capri etc that has been set up for a small V8 can now be certified with a larger version of the same engine, &/or potentially turbocharged or supercharged, provided that it meets all of the requirements.
In reality, not a lot really changes. The need to prove adequacy is the hard part. Staying close to the old capacity limits will be fairly easy even if it's a little over. Going way over will be quite challenging
im going through the process of engineering a lsa enine in an lh...
you can also supercharger/turbocharger the original largest engine (308)
#52 Bigfella237
  • 4,377 posts
Posted 23 January 2015 - 11:02 PM
Where is that quote from moot?
That is certainly news to me and doesn't read at all like the NCOP for Light Vehicle Construction and Modification.
And it's definitely not like dear old NSW to relax a regulation!
#53 _moot_
_moot_
Posted 24 January 2015 - 05:56 AM
ncop isnt actually in force in nsw...
https://www.facebook...ThlNDI0YjI1NiJ9
#54 Bigfella237
  • 4,377 posts
Posted 24 January 2015 - 06:52 AM
Ah, thanks mate.
What your quote didn't include was that he's talking about ICVs!
From the same FB page:
Just before Christmas, RMS released Vehicle Standards Information Sheet 53, which defines whether a vehicle is considered to be an Individually Constructed Vehicle or a Modified Production Vehicle. It largely formalises the rules as they already were.
As previously explained ( in the quote above ), the "capacity limit" rule that used to apply under the NSW Code of Practice, and the similar rule that is still in the National Code of Practice, is not part of the new definition of an ICV. This means that an increase in engine capacity alone will not make a vehicle individually constructed.
As I stated earlier in this thread (post #7), ICVs aren't subject to the same capacity limits as modified production.
But I wasn't aware that NSW hadn't taken up the National Code Of Practice (yet), bloody typical...
#55 _Liam_
_Liam_
Posted 24 January 2015 - 07:07 AM
All this doom and gloom and all he could was just put a 350 crank in and go from there. Haha
#56 Bigfella237
  • 4,377 posts
Posted 24 January 2015 - 07:15 AM
Damn this gets confusing...
From the NSW RMS website, the Vehicle Standards Information No 6 ( download .pdf here ), page 2 says:
CODE OF PRACTICE FOR LIGHT VEHICLE MODIFICATIONS
Vehicle Standards Bulletin (VSB) No.14 National Code of Practice for Light Vehicle Construction and Modification outlines the minimum design, construction, installation and performance requirements for modifications to light vehicles, for building individually constructed vehicles (ICVs) and for the certification of certain imported vehicles. Following the guidance provided in VSB 14 will help ensure that work undertaken will meet the standards set down in NSW regulations. Most of the modifications listed in the Order have corresponding practical guidance in VSB No.14.
VSB No.14 is available on the [Commonwealth] Department of Infrastructure and Transport website – see page 18 for contact details.
This sounds to me a lot like NSW RMS is directing me to look at the NCOP??
#57 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 24 January 2015 - 12:08 PM
Is anyway of making 400sbc look like a 350sbc so no one could tell difference?
#58 _Bomber Watson_
Posted 24 January 2015 - 12:17 PM
They do look the same, but the 400 has one less welch plug on the side of the block.
Honestly no one would pick it.
But thats besides the point....
#59 lakeside
lakeside
  • 2,703 posts
  • Car:LC SBC
Posted 24 January 2015 - 02:18 PM
Not all 400's have 3 plugs, some have 2 like the 350
#60 _moot_
_moot_
Posted 24 January 2015 - 07:40 PM
Ah, thanks mate.
It reads like that but its not just for ICVs. There are lots of 'loop holes' at the moment. I suggest you talk to a few engineers. You may be surprised
#61 TempesT
TempesT
  • 493 posts
  • Name:James - JImmy or Jim
  • Car:LX hatch
Posted 26 January 2015 - 08:53 PM
correct nsw is a mine field and its all down to what your engineer is willing to take on.
It is hard however as the NCOP is being treated like a code of practice or guideline doc. Certifying engineers dont need to follow it word for word but theu have to cross their t's and dot their i's soo much more so when it all goes wrong their ass is covered. Most will just direct you toward the NCOP to keep it easy and relatively low $$$.
Be interesting to know what hoops your being made to jump through following the larger engine capacity route moot
#62 SamBam
SamBam
  • 435 posts
Posted 27 January 2015 - 10:35 AM
The 400 block i have is a shp dart block so to answer about welsh plugs ive got 10 in total, with 3 on each side. Bit hard to see in this pic but I'll take another tonight for those interested
Ok so the pic didnt work off my phone ill jump on the lap top tonight and upload it
#63 _Liam_
_Liam_
Posted 27 January 2015 - 07:50 PM
You can keep the 400 block mate and put a 3.48" Crank in there, giving you a 372, which is below the cut off either which way they go, saves you $1500 for a block.
Edited by Liam, 27 January 2015 - 07:58 PM.
#64 _RedSS_
_RedSS_
Posted 14 March 2015 - 11:38 PM
Go see Enkleman and associates in braeside.
They engineered my 350 in the hatchback .
