Coolants, any preference for what brand
27 replies to this topic
#1 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 24 January 2015 - 07:28 PM
G'day All
Have just picked up a NOS Natrad 3 core radiator for the SS as the old one is RS rotten
Who uses what coolant and are they much a muchness as to what each brand does
Did hear just to put tank (rain water) into it of which I have about 4,000 litres outside the back door but is the old saying you get what you paid for right  :dontknow:
Barry
#2 _76lxJAS_
_76lxJAS_
Posted 24 January 2015 - 10:56 PM
I use nulon anti freeze anti boil, (green) then top up with rain water,
have never had any issues with it, and if you have any leaks the green can help you see it.
#3 Bigfella237
Posted 25 January 2015 - 12:03 AM
If you plan on attending track days and the like, I believe most drag tracks etc. don't allow glycol-based coolants because they're too hard to clean up.
Although if you live somewhere that dips below zero in the winter then anti-freeze is pretty much essential. Not just because frozen water prevents circulation when you first start up, but water actually expands just before it freezes and can easily crack a cast iron block (I think Mythbusters did a similar experiment by freezing a cast iron ball full of water).
Antifreeze aside, a lot of the "old school" used to swear by soluble oils like Bars used to sell in those little ring-pull cans (Bars the brand, not the place), it was basically just water soluble machine oil that was supposed to lubricate water pump seals and provide corrosion protection but it had some unwanted side effects like gunking up too.
But this is the 21st century and there are some much better alternatives around, for example Red Line make a product called "WaterWetter" which has corrosion protection too but mainly is supposed to "double the wetting ability of water" allowing much better heat transfer (I'll let you read their blurb).
So I guess it depends on your situation, where you are and what you need it to do?
Whatever your do, I suggest at the very least you use distilled or well filtered water and some kind of corrosion preventative, especially in any motor that has alloy parts.
#4 RallyRed
  • 8,176 posts
Posted 25 January 2015 - 08:11 AM
I use Nulon as well....no problems with it .
I originally went with it because its made here in Australia.
Not sure you are planning any track days ...but I think the glycol additives are OK as long as you can demonstrate an effective catch/overflow tank.
Regards
#5 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 25 January 2015 - 08:15 AM
Ive only ever used tap water in red 6s.
I cant recall having any problems with it.
#6 _LHSL308_
_LHSL308_
Posted 25 January 2015 - 08:22 AM
I use the Burson brand concentrate anti freeze anti boil and mix it 33% anti freeze/anti boil and 67% water. Keeps all my cars cool and have never had issues with mine either. You can buy it from Bursons for around $40 for 5 litres.
Edited by LHSL308, 25 January 2015 - 08:26 AM.
#7 fatslr
fatslr
  • 1,247 posts
  • Name:Garth
Posted 25 January 2015 - 10:00 AM
I use Toyota long life in all my vehicles ,after 10 years I pulled the lower hose off water pump in my old 80series and the neck looked brand new not an ounce of corrosion.
#8 _ChaosWeaver_
_ChaosWeaver_
Posted 25 January 2015 - 10:27 AM
^^^  That's the one I heard to use ...........  :)
#9 _Tangey_
_Tangey_
Posted 25 January 2015 - 10:53 AM
You want Nulon Ultra Cool , glycol free, best for our mature aged vehicles.
#10 SPONGY
SPONGY
  • 30 posts
  • Name:Warren Curtis
  • Car:LJ Torana
Posted 25 January 2015 - 11:52 AM
Always used Nulon Ultra Cool in all the old holdens that I have owned, had no problems.
#11 Indy Orange
Indy Orange
  • 2,962 posts
  • Name:Paul
Posted 25 January 2015 - 01:35 PM
I use Tectaloy Xtra Cool with distilled water, makes about 10litres,no problems so far.
#12 dattoman
  • 16,488 posts
Posted 25 January 2015 - 01:55 PM
Toyota or Holden genuine coolant in the good ones
Textaloy TEX500 concentrate with distilled water in everything else
#13 _Bomber Watson_
Posted 25 January 2015 - 02:12 PM
Toyota extra long life coolant in the daily, and will use it in the LJ. $93 for a 20lt drum, way cheaper than the "nulon long life" and the like rubbish from Autobarn or similar.
Mini gets the cheep "clean team" radiator coolant, usually $4.99 per 5lt bottle from autobarn, has no anti freeze, just anti corrosive, but it never gets below freezing here so suits me perfectly.
Might even get the shits and just run the LJ on that stuff to.
Edited by Bomber Watson, 25 January 2015 - 02:12 PM.
#14 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 25 January 2015 - 02:21 PM
Have a contact at Bursons so that would be the cheaper one
Now being a (very) mature aged driver with a mature aged vehicle, that's looking fairly promising
So this makes 3 I will consider and will have to do it fairly quickly as it's not exactly cool around these parts, was 37 under the back verandah a few days ago and it can reach over 40
Thanks ..... Barry
#15 _Bomber Watson_
Posted 25 January 2015 - 02:23 PM
Does it get below freezing there Barry?
If it does you need glycol.
#16 _walpolla_
_walpolla_
Posted 25 January 2015 - 04:36 PM
I have always liked and used Nulon - and still do.
However, check out these pix .
This happened about 4 years ago. I was gradually doing work on the LH, and did a new water pump, radiator and thermostat. Obviously the block was drained to do this. Once assembled, I refilled with the Nulon concentrate, and (I thought) all good.
 Zero kilometres, and about 3 or 4 starts in the shed,I looked in the radiator and saw stuff I did not like the look of. Battery was only connected during the brief starts - so electrolysis should not have been an issue.
 Drained the radiator by dropping the bottom hose and a cross between crystals and jelly came out.
 So I removed a few more bits and the following pix are what I found. Nulon were contacted, and what had happened was a reaction to another type of coolant.
 What it was I have no idea. Nulon and I agree that it was most likely what was in the heater core, as the radiator and block were dry before refill.
 So, a new pump, thermostat,and housing, and a good radiator clean out, plus flushing the heater and block thoroughly, refilled with the same stuff. No further issues.
  The Nulon Company were good about it. (also Autobarn) Thanks Nulon and Autobarn.
       regards,Rod.
Edited by walpolla, 25 January 2015 - 04:38 PM.
#17 Bigfella237
Posted 25 January 2015 - 05:19 PM
Lucky you caught that Rod, what a mess!
I'd hate to see someone do this and then set straight off on a summer holiday.
#18 _Muzzy_
_Muzzy_
Posted 25 January 2015 - 05:29 PM
I use the Nulon long life OAT RED coolant, I have read it's best for the full alloy radiators , only time will tell
#19 _Mint_
_Mint_
Posted 25 January 2015 - 05:47 PM
Nulon Ultra Cool for me too its just a straight corrosion inhibitor with no glycol(I hate the stuff)
#20 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 25 January 2015 - 06:12 PM
Get below freezing  :wtf:  Try down to -5 in Winter to some times +40 in Summer but normally around the mid 30's
With such a large range of temps, picking the right coolant is not easy
In Summer, we do not have all that many runs with our car club because of the heat and virtually all of our cars are not air conditioned so it is uncomfortable to be out in it
That is the main reason I have had 3 core radiators in all of my old cars
Barry
#21 _447SBC_
_447SBC_
Posted 25 January 2015 - 11:12 PM
Evans waterless coolant
#22 _ck1971_
_ck1971_
Posted 26 January 2015 - 04:10 AM
Aren't the red and green coolants for different applications? I thought I read somewhere that they have different chemical compositions for different alloys in different engines. It might be a good idea to do a search of what the coolants are recommended for.
ck1971.
#23 Pop's-SS
Pop's-SS
    Pops
  • 4,971 posts
  • Name:Barry
Posted 26 January 2015 - 01:00 PM
       regards,Rod.
G'day Rod
Did you only put in the concentrate or did you pre-mix or even concentrate then added the balance in water  :dontknow:
Barry
#24 _walpolla_
_walpolla_
Posted 26 January 2015 - 04:44 PM
Barry,I premixed the concentrate in a bucket and added it that way.  Topped up with clean water (we have good tap water) with engine running til the thermostat opened. Everything well and truly mixed properly .
 The problem was one coolant leftover in the heater core we think, not compatible with Mr Nulons chemicals.
  No big deal, just a spectacular mess.
                      regards,Rod.
Edited by walpolla, 26 January 2015 - 04:45 PM.
#25 Ice
  • 15,211 posts
Posted 26 January 2015 - 05:01 PM
Tectoly gold for years havnt had an issue yet
