hi fellas im currently running my slr 5000 with hq brakes without a booster (just master cyl) so i can fit my clutch slave cyl in its a wilwood 1 " bore master cyl mounted on a custom bracket it all works fine but i would prefer some sort of brake/ clutch pedal assembly mounted on a pedal box complete i can see from the pics this is what litre 8 runs does anyone know what type it is or can litre 8 help me out with some advice as to what is the best fitt
litre 8 clutch/brake pedal setup
_azureblueslr_
, Jul 23 2006 12:27 PM
1 reply to this topic
#1 _azureblueslr_
Posted 23 July 2006 - 12:27 PM
Posted 23 July 2006 - 12:57 PM
When I did the brake conversion there was no off-the-shelf pedal boxes readily available so I got a Tilton balance bar setup on had it tig welded onto the existing brake pedal with the two master cylinders mounted on the firewall.
The clutch pedal was drilled to accept the clutch master cylinder arm.
Datto is the man to ask for the easiest way to achieve this same functionality these days though I dont think the pedal box setups are cheap.
