106 Db twin system TOO LOUD
#1 _TORANA IN THE BLOOD_
Posted 24 July 2006 - 03:48 PM
End result 106Db and the limit is 96Db not good but what happens next is worse while driveing home from being tested i was pulled over and defected for roll cage,air filter and seat belts.Not a bloody thing about exaust an noise.
As a result of all this i let the car run out of rego and now have to get a blueslip done an have two questions and plea for help.
Is there any one in sydney that might be able to help me out with a standard exaust or mufflers wheather its a loan or cheap price im sure there is someone out there that this has happened to and i do not want to spend the money on making it quiet when its not what i want and no that i will prob never be done for it again.
Also does anyone no of a good blueslip place in sydney (campbelltown area)which is torana and old car friendly i do want my car to be totaly road worthy thats not a prob as realy dont think im gonna have any probs except my key falls out egnition.I just dont wanna be stuffed around by some idiot that will pick me down to the bone when its not needed.
Any help will be much appreciated even if its just some ideas on what i could do to get car passed for noise i was thinking of just packing my exaust with muffler packing then removeing once passed what do you think will it work
#2 _Herne_
Posted 24 July 2006 - 03:58 PM
You could pack the tail pipes with steel wool - be sure to poke it well in or it may blow out when they test the exhaust. This will quieten it down....be sure to take it out again with a hooked piece of long wire.
BUT
If you do that its only going to be a matter of time until you get picked up and sent for a re test for noise. The same will happen if you borrow a cheap muffler/s.
The best advice I can give you is to save your pennies and purchase the correct mufflers then as you state your car will be "totally roadworthy" Thinking you will probably never get done for noise again is 'totally wrong dude' lol
Good luck
Herne
Edited by Herne, 24 July 2006 - 04:00 PM.
#3 _lx5008_
Posted 24 July 2006 - 04:06 PM
as far as the other defects go you will have to get a engineering report to cover the mods and then that is right for ever aswell.
its the only way to go, next time you get pulled over you just show then the engineering report and all is ok. you hope
#4 _draglc_
Posted 24 July 2006 - 07:40 PM
Its a prick of a situation, but if you can make it legal for the test, not saying your or i wont get pulled up again, but hey, you can spend a lot of money trying to get it fixed like i did, and still fail.
A1
Posted 24 July 2006 - 08:30 PM
109.3DB.... yeee Har
I paid $600 and got a complete new exhaust system and i was still over the limit. but not by alot.
What we did to get passed was to make "fake gaskets" that bolted in place of teh tailpipe gaskets, and had 4x 3/8" holes drilled in them... Instant 93db.
This was done because i was only at 97db and there was no other way to keep it any quieter!
I'd get your exhaust looked at and see what they can do muffler wise.. and use the plates to get you out of trouble and then your as legal as you can be!
Take the car to Hume Mufflers, Big dave up there will sort you out. Tell him Tiny with the red HQ monaro sent you from Rock Ape's workshop... ( ive met dave a few times and he's done my exhaust and gerbox x-member but he may not remeber me).
Good luck dude!
#6 _lx5008_
Posted 24 July 2006 - 08:47 PM
Posted 24 July 2006 - 09:20 PM
I'd say get the exhaust done as best you can without too much sacrifice, and then use the restrictor plates to get the defect cleared and live happily ever after!
And yes.. i do still have me plates... just in case
#8 _TORANA IN THE BLOOD_
Posted 24 July 2006 - 11:29 PM
#9 _TORANA IN THE BLOOD_
Posted 24 July 2006 - 11:42 PM
LX5008 does this mean you do blueslips and able to pass my defective exaust once under 96db because i will be on my newcastle if this is the case.true, thats the best way to beat this. we clear heaps of defects and do blue slip etc.
Also then you could say that you had one aus musle car that had way less db than hp
#10 _Azza_
Posted 24 July 2006 - 11:44 PM
Posted 24 July 2006 - 11:55 PM
Posted 25 July 2006 - 08:03 AM
#13 _lx5008_
Posted 25 July 2006 - 08:52 AM
yes mate we can do that, the car would have to be legal but. on the defect papers how did they defect you. is it part or full inspection ? and what did they defect you for. you can give a call for a chat on this if you like. 49683774LX5008 does this mean you do blueslips and able to pass my defective exaust once under 96db because i will be on my newcastle if this is the case.true, thats the best way to beat this. we clear heaps of defects and do blue slip etc.
cheers graham
#14 _draglc_
Posted 25 July 2006 - 01:10 PM
i tried everything, just a combination of hotdogs, gonzos, and bits of steel fixed it.
A1
#15 _MAWLER_
Posted 25 July 2006 - 02:27 PM
Cheers,
Posted 25 July 2006 - 05:03 PM
To a twin 2.5" system with a resonator and a straight through muffler each side with full tailpipes. 97Db.
Currently i run the system above with an "X" pipe and the straight through mufflers, but i havent had the sound level confirmed yet!
I used the plates to get below the 97 reading to get passed by the EPA and i'm more than happy to run where i am.. I'd HATE for it to be any louder than it is today!
Cheers!
#17 _MAWLER_
Posted 25 July 2006 - 06:02 PM
Posted 25 July 2006 - 06:06 PM
I'm pretty happy with them all over though i have heard rumors ( by my exhaust bloke) of them blowing appart at over 400Hp or so.. they split around the edges wehre theyre folded. I remeber at the time him reccomending a redback muffler if this happened but so far so good!
Cheers!
