Help on how to set up - low oil pressure light
38 replies to this topic
#26 _2ELCS_
_2ELCS_
Posted 01 May 2015 - 09:39 PM
The're called Hobb switches.... you can get them in different pressure settings.
I used a car horn in the race car...with a switch you could turn on after the engine started or had oil pressure...
your eyes are awfull busy in a race car...your ears a basicly along for the ride...
IMHO...
#27 WhaleOilBeefHooked
WhaleOilBeefHooked
  • 1,671 posts
  • Car:LJ GTR
Posted 02 May 2015 - 09:30 AM
A round trailer brake light mounted above steering wheel is one option I have seen in race cars......
#28 Bigfella237
Posted 02 May 2015 - 09:45 AM
Long before Autometer made such things, I pulled an old VDO gauge apart, threw away the guts and fitted a brake light bulb holder and a red lens.
It slotted right into the dash with all the other gauges, looked like a professional job, cost me nothing and was bright as...
#29 _Agent 34_
_Agent 34_
Posted 30 May 2015 - 06:59 AM
http://www.ebay.com....=item462d4adcfc
is this the switch i need.
It has 25KPA which i assume is the pressure.
shouldn't it be PSI
it says thiat it will fit
thanks in advanced
g
#30 Bigfella237
Posted 30 May 2015 - 07:13 AM
25kpa is about 3.6psi
Looks like it should fit?
#31 S pack
  • 15,745 posts
Posted 30 May 2015 - 08:27 AM
VDO 231.081 is the correct replacement oil pressure switch for the Holden Red 6.
#32 RallyRed
  • 8,180 posts
Posted 30 May 2015 - 04:59 PM
Hi Grant.....howd the tacho go?
From my old tech / TAFE days 1 atmosphere  = 101kpa  = 14.7 psi.
As Andrew says above, its about 3.6psi.
I think the generic Holden switches that make the ""oil""  light come on, are about 7psi...thus 3.6 is not much....and means its time to turn the engine off!!
#33 wot179
wot179
    Green Eggs and Spam
  • 6,784 posts
  • Name:Jesus Bloody Christ
  • Car:Goon
Posted 30 May 2015 - 05:26 PM
Good old Victor Bray used to have a big red square hella trailer light mounted to his dashboard with a "$" sign painted on it.
#34 _Gunmetal LH_
_Gunmetal LH_
Posted 30 May 2015 - 05:56 PM
Found this a little while ago AFTER I bought a 'sandwich plate' adapter. :banghead:
http://www.ebay.com....984.m1436.l2649
Attached File  $_12.JPG   28.91K   2 downloads
Would be VERY handy when trying to position a sender or switch with bugger-all room and trying to get the angle just right.
I only needed the 1x extra port for a pressure sender.  Now I've got 3x. :<_<:
#35 _Agent 34_
_Agent 34_
Posted 30 May 2015 - 06:25 PM
Am using " gulf western " 25 - 70 comp plus" in the car.$33 for 5 lts which i think is pretty good.
changed the oil today and took awhile of the pressure to come up which was a bit of concern but came up.
also noticed that the oil filter was pretty loose so when I put it back put the hose clamp and some tie wire to another point.on the car.
Drilled the sump plug as well.while i was there and tie wired it to the chassis
Col got the tacho sorted BUT it's 500 rpm out - need new tacho
Pete - i have an extender in the garage which i will try to use - but i have changed so much since the last outing i dare not change anything else prior to giving it a good run and see what happens.
post this meeting im going to put the idiot light in
you could probably run this off the " external pump line " given thoes fittings.
G
#36 _2ELCS_
_2ELCS_
Posted 30 May 2015 - 07:03 PM
^^^^ I hope you tie wired the sump plug to the engine NOT the chassis ??????
#37 Bigfella237
Posted 30 May 2015 - 07:08 PM
Unless you have solid engine mounts of course?
Most tachos will have an adjustment inside them for fine tuning, separate from the 4-6-8 switch. There should be a little potentiometer on the circuit board somewhere, it might be shown in the instructions if you still have them?
It shouldn't be a straight 500rpm out, it should be a percentage so the inaccuracy gets larger as the revs increase?
Edited by Bigfella237, 30 May 2015 - 07:12 PM.
#38 _2ELCS_
_2ELCS_
Posted 30 May 2015 - 07:24 PM
It still has rubber mounts....
#39 _Agent 34_
_Agent 34_
Posted 30 May 2015 - 07:48 PM
DOH !
Take Two tomorrow ! ha ha  !- cheers wayne - theres not many spots to wire to back there
Will check the tacho tomorrow it does have a switch on the back there 4-6-8 didn't check to see which one it's on. - i was amazed that i wired it up right that was a real bonus !
