Issues with Bendix Stromberg carburettor.
37 replies to this topic
#1 _RedKobra_
_RedKobra_
Posted 24 June 2015 - 01:29 AM
Vehicle takes several tries to start when cold and will stall at idle until warm. Whilst driving, power is lost when accelerating out of corners. Carburettor is a Bendix Stromberg. Smells of fuel and may have a slight leak. Image below.
#2 _Gunmetal LH_
_Gunmetal LH_
Posted 24 June 2015 - 01:55 AM
Is that idle shut-off valve working properly?
Looks like that rectangle bit in the centre of the pic should have some sort of cover on it?
#3 _RedKobra_
_RedKobra_
Posted 24 June 2015 - 02:40 AM
No idea, only picked up the car on Friday. Just looking for a quick fix until I get my 350 Holley, adapter plate, and throttle cable.
#4 _Bomber Watson_
Posted 24 June 2015 - 10:57 AM
Please don't use an adapter plate.
It could be any number of things wrong with the carb, but I would be looking at basics like clogged idle circuit and clogged accelerator pump nozzle, hole in accelerator pump diaphram, leaky shafts, have you checked the entire intake assembly for vac leaks, etc.
#5 TerrA LX
Posted 24 June 2015 - 03:23 PM
Photo of choke both on and off?
#6 _reefhog_
_reefhog_
Posted 24 June 2015 - 07:09 PM
It's about $40 for a kit for these carb., and they're pretty easy to rebuild. I would start by doing a rebuild, making sure everything is cleaned properly and the float level is set.
Are you using choke while it's cold? It shouldn't idle without using the choke until it has warmed up.
#7 _Macca97_
_Macca97_
Posted 24 June 2015 - 07:43 PM
I run the same carb on my daily, and please don't ruin it by putting a 350 holley on it, the strommys are a great carb,
all ive done is put a kit through it and no problems, cold start for me is 3 pumps of the throttle, and hold light throttle and starts straight away, than idles at 500-600 no matter what temp
#8 _oldjohnno_
_oldjohnno_
Posted 24 June 2015 - 08:48 PM
Do you know what the carb or engine was in originally? The later (HX and after I think) engines with emission controls had a very lean calibration that coughed and farted at the best of times. If it's one of these you'd be better to swap it for a HQ era carb or go straight to a new manifold with a Holley or Weber.
#9 _duggan208_
_duggan208_
Posted 24 June 2015 - 10:56 PM
For goodness sake don't use an adaptor. You would have the air of a 2 barrel carbie being stuffed in a tiny single little hole in the manifold. If you get a Holley, get the correct manifold.
regards
#10 _RedKobra_
_RedKobra_
Posted 25 June 2015 - 06:26 AM
The carby has a manual choke and the vehicle looks as though it never had one, as I see no holes in the dash where they removed it. In other words there's no cable connected other than the throttle cable, so I can only operate the choke from the engine bay. Would this vehicle (UC) previously have had a carby with an auto choke, or is there a carby with auto choke that fits my manifold? (Choke lever in previous photo is directly centre-right of long spring.)
regards
With the correct manifold, will a 350 Holley use much more fuel?
Part of my thinking to get the 350 Holley and nice chrome air cleaner now rather than waitng until I build a nice 202, was that at the moment I gotta put up with this eyesore... open to suggestions but that air cleaner is going in the bin right after I adjust it with a hammer.
#11 _Muzzy_
_Muzzy_
Posted 25 June 2015 - 06:57 AM
No auto choke on 6 cylinder UC, I think the 4 cylinder sunbird had one, has this engine been transplanted, also what size is it. In the 1 picture it looks like 173, which can't be be UC
Heaps and too big for anything less than a 202
Don't do that eBay the aircleaners worth money
Reply as above
Edited by Muzzy, 25 June 2015 - 06:58 AM.
#12 _oldjohnno_
_oldjohnno_
Posted 25 June 2015 - 07:02 AM
It looks like your existing carb is a late emissions-calibrated carb, an earlier model would run much better. If fuel economy is an issue the little Weber would be a better choice. You'd still need a two barrel manifold and adaptor. See this http://www.gmh-toran...6-weber-34-adm/ thread of Muzzys.
#13 warrenm
warrenm
  • 2,130 posts
  • Car:1972 LJ Torana
Posted 25 June 2015 - 07:12 AM
Attached File  8525210026_large.jpg   26.11K   3 downloads
The choke for the 6 cylinder UC is left side of the steering column, as circled in red, The 4 cylinder may have had an auto choke, too many years ago to remember, someone else will confirm. Give the air cleaner a sand & a coat of paint, it'll look as good as new, you could even cut the snorkel of for a "cleaner" look.
#14 _threeblindmice_
_threeblindmice_
Posted 25 June 2015 - 10:02 AM
Our 202 UC  takes a minute or two to warm up and stalls the first time you try to move it when cold , your loss of power is that only when it's not running at operating temperature ?
#15 UCgazman
UCgazman
    UC's FTW!
  • 1,343 posts
  • Name:Garth
  • Car:UC S̶u̶n̶b̶i̶r̶d̶ 5000!
Posted 25 June 2015 - 12:04 PM
4cyl starfire UC would have come with a Varajet carb with auto choke. OP's sig says he has a 1980 sunbird, which most definitely would have left the factory with a starfire.
#16 _SRV_
_SRV_
Posted 25 June 2015 - 02:43 PM
Put a choke cable on it then?
#17 _RedKobra_
_RedKobra_
Posted 25 June 2015 - 04:21 PM
Don't do that eBay the aircleaners worth money.
 Still think so?
#18 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 25 June 2015 - 06:21 PM
Don't smash up the air can, that is not the problem,the 3.3 red label air can has the same fittings on the base,the "unused" piece in the picture was used on "emission" type carbs. and was held in place by a "special" clip.
The diaphragm on the silencer operated a "winter/summer" flap (eng. temp. sensitive)  that was connected (via other shit) to the exhaust manifold by a piece of convoluted pipe to the "oven" on the exhaust manifold.
Either change the can to of these
Attached File  ac.JPG   219.34K   0 downloads
or change  the carb to one of these or the equiv. weber, both seem to have same prim./sec/ throats... parts availability pending.
Attached File  hw.JPG   230.14K   2 downloads
or...The "leaner" type carbs as already said can be a bit of headspin,,,tried that on a 253 with "emissions" carb. very similar problem,put an old emissions carb. on...much nicer.   :)
#19 _Muzzy_
_Muzzy_
Posted 25 June 2015 - 06:40 PM
 Still think so?
Maybe not LOL
#20 _duggan208_
_duggan208_
Posted 26 June 2015 - 12:14 AM
You could look at keeping the stock type air cleaner can and connect a flexable air hose to it and poke the other end out somewhere behind the grille and give your carbie, whatever you chose, plenty of cool clean air uneffected by hot dirty engine air from inside the engine bay.
regards
#21 _RedKobra_
_RedKobra_
Posted 26 June 2015 - 01:22 AM
regards
I think a pod filter would do a better job in that regard but I'm not going for that look. Cheers.
#22 _RedKobra_
_RedKobra_
Posted 26 June 2015 - 02:40 AM
It's not much good with those dents in it and the horrid mounting bracket seems to be damaged. You reckon anyone would want this and how much should I ask for it? Selling anything under the value of a block of beer is just wasting time IMHO. :P
...or change  the carb to one of these or the equiv. weber, both seem to have same prim./sec/ throats... parts availability pending.
Which model Holley is that?
#23 _RedKobra_
_RedKobra_
Posted 26 June 2015 - 02:44 AM
Well unfortunately mate, I got nothing on that side and the other side operates the lights.
#24 _oldjohnno_
_oldjohnno_
Posted 26 June 2015 - 07:15 AM
5200, it's a copy of the Weber built under licence. An actual Weber will be cheaper and much easier to find.
#25 EunUCh
EunUCh
  • 2,774 posts
  • Car:japos
Posted 26 June 2015 - 04:27 PM
The dings don't look that bad in the picture?
Got no idea what can is off...some old holden...looks GTRish but could be wrong probably used on heaps of em.
When you say it smells of fuel...is that from the exhaust or a raw fuel smell from under bonnet.
Best identify the carb before going deeper...i knew some one threw up a list not long ago of applications somewhere :)
http://www.gmh-toran...fo/#entry326149
Edited by EunUCh, 26 June 2015 - 04:40 PM.
