Painting engine parts
#1 _LJ355_
Posted 27 July 2006 - 05:42 PM
#2 _MRNOS_
Posted 27 July 2006 - 06:23 PM
#3 _LJ355_
Posted 27 July 2006 - 06:33 PM
#4 _MRNOS_
Posted 27 July 2006 - 07:19 PM
Edited by MRNOS, 27 July 2006 - 07:19 PM.
#5 _LJ355_
Posted 27 July 2006 - 07:48 PM
#6 _Pete_
Posted 21 August 2006 - 08:16 PM
Posted 21 August 2006 - 08:24 PM
#8 _Pete_
Posted 21 August 2006 - 08:39 PM
Posted 21 August 2006 - 09:11 PM
But then who'd use a std pump, or not pull it apart and adjust it........
Grant..
Posted 21 August 2006 - 09:43 PM
#11 _LX406_
Posted 22 August 2006 - 05:54 AM
2 things, fo I need to fully remove the VHT, and do I need to prime the block?
#12 _Pete_
Posted 22 August 2006 - 05:57 PM
We have a Glasurit system at work so thats what I used, I used a Glasurit "wet-on-wet" etch primer which I sprayed a light coat on and then gave it a 25min Bake in the booth to make sure its dry, then two coats of my custom mix of silver basecoat colour, then two coats of HS Glasurit Clear.
If you want to try paint over an existing finish it might be a little questionable, but I think if the VHT is well cured you should be ok if you rub it down well so the paint has a good surface to "key" into. The hardest part would be getting all the ingrained oil and grease off an existing surface so the paint has the best chance of sticking. I used a "wet on wet" primer so it didnt need to be rubbed down.
No 2pack manufacturer will guarantee their paints on a high temp surface like an engine block so its always going to be a risk but it does look good.
Bare metalling the block by dipping etc is probably the best bet, and if you wanna get adventurous you could smooth it (lots & lots of work) and also putty it up and rub it down for an ultra smooth look but really its the domain of showcars.
