Hi guys, I currently have HT engine mounts on my 308 and will be replacing the rubber mounts but before I do, I was wondering if anyone is using these and had any issues. I've read some of the threads but most compare original mounts to HQ. The HT mounts are same height as HQ at 45mm but I'm not sure if there are differences in the bolt hole locations. I have had the block in the car (not currently) to dummy up some things and don't see any glaring problems, but take on board I have little (read none) mechanical experience. I haven't got the distributor and not sure on pinion anglers but the block does seem to drop down toward the rear, even with correct trans Xmember. Extractors and sump don't appear to have any clearance issues. I will be running:
Stroked 308
Pacemaker extractors
High Energy sump
T400 auto
Harrop dual plane
Holley Avenger carb
Cheers Ron
