who is building it?
Gday......Im putting it together but machining is being done at Pryce Engines Newcastle
A quick explanation is.....
Yes the VN head is biased toward the intake, flow wise. If you wanted to compensate for the average exhaust port by increasing the exhaust duration then be aware that this will bleed off compression and therefore torque lower in the RPM range, not good for a street engine.
Increasing exhaust duration will however make more upper RPM HP and stop the engine nosing over after peak HP. This is desirable for an engine intended to operate above about 6000 rpm.
Personally I have found that single pattern cams will make more torque and be more responsive in a street application, regardless of the head used. Once the owner wants to rev it up and make a bit more HP at the expense of mid range torque then by all means give it some more exhaust duration.
Short answer..... the 286 will be fine and really is hard to beat in any street Holden V8.
JMHO
Thanks Andrew....your explanation makes sense......this engine will be a mild streeter so no need to have peak Hp and torque towards the upper end of the rev range....
Im after good mid torque and i would like it to be a comfortable driver.
The comments above are from a man who know his 308's so I would listen to what he has said.
From my experiences, the Perfomer (dual plain) and Crane H286 hydraulic is probably the best set up for a good streeter 308. Not had a H286 with a VN headed engine but from all accounts I have heard, they also work well.
Thanks Gerry....Im listening with open ears.....and all the info I can find on the net and forums points to the same conclusion as Andrew just explained....so Im going to go with the H286 set up.
Thanks everyone
Al
