Crank case pressure
49 replies to this topic
#26 TerrA LX
Posted 05 November 2015 - 11:06 AM
^ Agree.
Yes but the pcv valve is not enough to vent a performance engine which needs to breath freely ..also pcv s suck in contaminated air which can cause detonation which is ok for stockers but not good for high performance engines
#27 myss427
myss427
  • 1,636 posts
Posted 05 November 2015 - 01:19 PM
Fix the rings and put a vacuum pump on it. On performance engines they stop oil leaks, free up some power and look pretty cool.
#28 Shiney005
  • 9,729 posts
Posted 05 November 2015 - 02:21 PM
I've never really thought about it until now, but would the high crank case pressures also restrict oil flow back down to the sump? I have seen a lot of work done with a die grinder to 308 blocks to help stop the top end from filling up at sustained high RPM.
#29 TerrA LX
Posted 05 November 2015 - 04:17 PM
^ yes, most definitely
That is why some vent straight from and return to (catch can oil) straight to the sump..
#30 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 05 November 2015 - 05:01 PM
Yeep thats right, i said a couple of posts ago to vent from the sump and one of the main benefits is to allow oil drainback to the sump where u need it.
If u are running an electric fuel pump then u can vent from the pump block off plate
#31 jd lj
jd lj
  • 2,119 posts
  • Name:James D
  • Car:LJ
Posted 05 November 2015 - 06:12 PM
If you run a vent from the sump I'd assume that it'll work better above the oil level. Otherwise would it possibly have a kind of hydraulic lock.
My 202 high volume sump has a port quite low on one side for an oil temperature sender which is no longer being used. I'd wondered if plumbing into this would be advantageous.
I know that I have some sump pressure that needs to be dealt with, but I'm not in a position currently to do a rebuild. I've seen a lot of track cars run a hose from a side plate to the catch can, how effective is that method?
#32 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 05 November 2015 - 09:03 PM
The vent needs to be above the oil level.
directly out of the sump is best . then fuel pump flange , then siďeplate.anything is better than nothing.
#33 _Bomber Watson_
Posted 05 November 2015 - 09:05 PM
I run mine from the sideplates.
A lot better than the rocker cover.
#34 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 05 November 2015 - 09:39 PM
The problem is the bad ring seal, not the lack of a vacuum pump. If your house kept filling up with water the smart thing to do would be to fix the roof rather than put a bilge pump in the loungeroom...
 On the money Oldjohno , i have just experienced this , was a fresh engine had slight fuming and blew rear main seal ... rings stuck inside piston groove .
#35 _Bomber Watson_
Posted 05 November 2015 - 10:20 PM
*hides bilge pump in loungeroom*
#36 _oldjohnno_
_oldjohnno_
Posted 06 November 2015 - 05:05 AM
Exactly. The manifold side of the sump in line with a main web is the best spot. The sideplates aren't really ideal because they are still above the drainback holes in the block, though it's what I use and it seems to be OK. The front plate has one more drain hole than the rear so would probably be the better choice.
#37 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 07 November 2015 - 12:57 PM
If the pump cant keep up its time to get into the dinghy.
#38 _Agent 34_
_Agent 34_
Posted 07 November 2015 - 04:45 PM
a dingy in the lounge room ?
#39 _oldjohnno_
_oldjohnno_
Posted 07 November 2015 - 06:18 PM
Well you can't leave it in the kitchen. The crocs would chew it to bits...
#40 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 08 November 2015 - 04:55 PM
I hate fu##n crocs .how did they get that far south
#41 _oldjohnno_
_oldjohnno_
Posted 08 November 2015 - 05:02 PM
Straight down the hallway I guess...
#42 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 08 November 2015 - 06:28 PM
Were you on that swamp people show johnno.
#43 _oldjohnno_
_oldjohnno_
Posted 08 November 2015 - 07:27 PM
Yep that was me with the banjo. I was smiling cos I like to show off my teeth - both of em...
#44 _STRAIGHTLINEMICK_
_STRAIGHTLINEMICK_
Posted 08 November 2015 - 09:18 PM
Ha , Thought the photo looked familiar. Good onya Johnno
#45 _LX355SLR_
_LX355SLR_
Posted 18 November 2015 - 07:16 PM
i have installed a PCV valve and it has made no noticeable difference. leaks the same amount but could just be because the seal is gone already. I have out a plastic bag over the rocker cover filler hole and at idle is slightly sucking the bag inward but would obviously be a different story at high revs.  Vac pump sound interesting. Where are these being installed...of the maniofld?
#46 _Mint_
_Mint_
Posted 18 November 2015 - 08:20 PM
I recently tried a bottle of this stuff http://rislone.com.a...in-seal-repair/ on my weepy neo rear main seal after another guy used it and said it worked great so far its doing the job
#47 TerrA LX
Posted 19 November 2015 - 04:40 AM
There should be no manifold vacuum at hi rpm coming thru the PCV, the valve should close and all engine pressure and blow by at hi rpm should flow into the air filter.
Edited by TerrA LX, 19 November 2015 - 04:42 AM.
#48 _oldjohnno_
_oldjohnno_
Posted 19 November 2015 - 05:02 AM
At lower vacuum levels like at WOT the PCV is actually at it's most open position, to give the most flow despite the low vacuum. If the engine is in good shape there shouldn't be much backflow at all into the air filter.
#49 TerrA LX
Posted 19 November 2015 - 05:28 AM
You are correct, I should have been more definitive and said at high vacuum conditions, which would be regardless of Rpm.
#50 TerrA LX
Posted 19 November 2015 - 05:31 AM
