Hi guys,
I kno wits probably been asked before but i cant find it, my LH 308 has a problem with the steering shaft being close enough to touch the extractors, how can i recitfy this problem.
JNR_ATE
LH + 308 + STEERING SHAFT HITTING
_JNR_ATE_
, Jul 30 2006 09:26 PM
3 replies to this topic
#1 _JNR_ATE_
Posted 30 July 2006 - 09:26 PM
Posted 31 July 2006 - 03:55 PM
with a hammer!
seriously, you might have to re bend your extractors a little, any exhaust shop should be able to do this.
is it hitting the shaft or the rubber knuckle?
#3 _the gts_
Posted 31 July 2006 - 07:36 PM
With a Hammer??? you butcher
mate you can move the knuckle a little bit up or down by loosening the cotter pins.
You can also try loosening the bolts under the steering column inside the car and move the colum to the left or the right a bit. and lastly you can loosen the two bolts that bolt the engine mounts to the cross menber and lift the engine slightly on one side.
its no big drama to fix just a slight adjustment here and there
#4 _JNR_ATE_
Posted 01 August 2006 - 02:00 AM
Yeah that it pretty rough, lol
Nah its hitting on the shaft, might have to try these "minor" adjustments GTS speaks of,
JNR_ATE
JNR_ATE
