LS1 Conversion into LX
34 replies to this topic
#1 _Ryno364_
_Ryno364_
Posted 21 December 2015 - 02:30 PM
Hey Guys, I'm at that stage now where I have to make my damn mind up and select my engine whether it be an LS1 or old school 383 Chev. I am starting to leaning towards a LS1 (from a VY) and auto combo which I can purchase 2nd hand for $2800. From what I've read there are mixed reviews on this forum about the level of difficulty but what's everyone's general consensus about the 'pain' of putting one of these engines into a Torrie versus the end reward?! I've set myself a budget of around $15k, has anyone got like an itinerary of items for the conversion i.e. sump, wiring harness, fuel system etc. I'm all for a bit a of challenge and I was going to attempt the wiring side of it myself.
Have done the 'double knuckle' steering conversion and trimmed the chassis rails so extractor clearance shouldn't be too much of an issue.​ I realise there is a wealth of knowledge on this forum if I did need some assistance at a later date. Please let us know your thoughts.
Thanks Ryan
#2 _Bomber Watson_
Posted 21 December 2015 - 04:10 PM
Thats a very pretty car.
A few lads have pumped up a full Itinary, Andy has one of the most conclusive thus far.
http://www.ls2lxhatch.com/
ls2lxhatch on here.
Personally, if you could go dollar for dollar hp for hp either way, I would take the old school chev, sounds way better and you will have something that drives like a hot 70's Holden not a commy.
#3 _Ryno364_
_Ryno364_
Posted 21 December 2015 - 04:56 PM
Cheers Bomber â€‹    yeah theres just something about the sound of old skool 383 chev with high compression and a big roller bump stick   :driving: I'll check out Andy's post and try weigh it up      â€‹
#4 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 21 December 2015 - 05:15 PM
Ryan I am in the middle of a ls2 and Magnum conversion
if I was you I would go the chev
the ls conversion is a night mare just trying to get things to fitted etc wires and alike
but in saying this I have just had some bad luck with people that I was dealing with
others have done it and said it was easy but that also depends on your skill level
#5 rexy
rexy
  • 3,768 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 21 December 2015 - 05:20 PM
If you can, go LS.
I love my LJ. Starts first time, every time. No stumbles or carry on.
Goes like the clappers and economy is pretty good.
#6 Bigfella237
Posted 21 December 2015 - 05:40 PM
That K-member and rack looks like they were printed on a 3D printer? :P
My personal preference would be a later Gen IV LS motor, 6.0L (364ci) or 6.2L (376ci), but I think you've really left it too late to start mocking up, especially as you'll most likely have to re-work the trans tunnel for a later gearbox, drill holes in your pretty firewall etc. None of the usual companies (that I've seen) has really got the conversion kit down-pat yet, there's still a lot of screwing around to be done.
Whereas an old school (Gen I if you like) Chev engine is pretty much guaranteed to just bolt straight in.
#7 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 06:53 PM
It is hard to beat the simplicity of a 383 SBC with a carby. The 383 SBC with a carby does not require CATs or expensive EFI fuel systems.
The axistr power steering rack is a straight forward bolt on will fit with a SBC but will not a fit with an LS without relocating the oil pump pickup and reworking the oil pan.
If I was to do it again then I would have a carby 383 SBC. Toranas should be thirsty and grumpy.
Edited by ls2lxhatch, 21 December 2015 - 06:54 PM.
#8 _LS1 Taxi_
_LS1 Taxi_
Posted 21 December 2015 - 07:01 PM
My big cam LS1 is grumpy...but not thirsty :lol:
#9 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 21 December 2015 - 07:24 PM
I have one of axistr power steer racks with a LS2 it was easy and it did my head in to get clearance but its done
That's ment to be wasn't easy ...sorry I was in a rush
#10 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 07:25 PM
Did you relocate the oil pickup to the passenger side?
Edited by ls2lxhatch, 21 December 2015 - 07:26 PM.
#11 _LS2 Hatch_
_LS2 Hatch_
Posted 21 December 2015 - 07:32 PM
It's not an easy call.
Considering the state of your car, the Chev would be the safe option.
Once done, I don't think you can beat the late model engines. They are reliable and go hard with far less work.
You won't need to cut and shut your tunnel if you go auto, but you will with a 6 speed manual.
Looking from the outside it seems those that are still in the process say go Chev, those that have it completed and up and running say go LS.
LS1 Taxi would go any other way if he did it again, and I would say that goes for LS1 Hatch and I as well.
Depends what you want out of your car when finished. No one said it has to stay injected if you go LS.
There is a green four door in the Canberra Torana Club that has power steer and air conditioning, and the set up is awsome. Gerry may be able to help with some photos of that one.
Either way I don't think you can go wrong. Either way it won't be slow!!
Once you make a decision, we need a thread and pictures pictures pictures!!!
#12 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 07:34 PM
If you buy a VY LS1 and auto then you will need the following. The prices are a rough guide.
Computer VAT delete and tune $450 or MAFless tune $800+
Wiring harness $1200
Oil Pan $800
Custom made headers $2000+
Cats $500
Fuel system $500-$2000
Engine Mounts $250
Cable-X to run mechanical Torana speedo off the electronic pulse from the 4L60e. $500
I don't think the VY Auto 4L60e will fit in your transmission tunnel. I had a new transmission tunnel fabricated to fit the 4L65e in my hatch.
15K should be enough for engine, gearbox, exhaust and fuel system.
You should work up a a couple of spreadsheets with the costs of all the parts you need for the different engine options (brakes $1500+, cooling system $1000+, tailshaft $500, diff $1500+, suspension). It adds up quickly
#13 BIG KEV
BIG KEV
  • 1,218 posts
  • Name:Kevin
Posted 21 December 2015 - 07:35 PM
No standard oil pick up and Moroso sump
No windage tray as I have a strocker crank
I made my own mounts and removed the factory ones of the K-frame
I spoke with Jason from Tuff mounts and if the mounts were that bit higher it would work
The troubles with after market mounts ,they foul on other things like a/c
By making the one I did I sat the motor where I want and clears
#14 _LS1 Taxi_
_LS1 Taxi_
Posted 21 December 2015 - 07:42 PM
VY auto (4l60e) fits with a slight tap with a hammer to clear the gear selector shaft.
Those prices seem high too Andy.
I bought my stuff 3 years ago so it may have all gone up? Dunno.
#15 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 07:57 PM
I did not want to raise the engine as is caused too many other problems.
I think moving the oil pickup to the passenger side like dirtbag did is the simplest solution.
More pictures in this thread.
Edited by ls2lxhatch, 21 December 2015 - 08:00 PM.
#16 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 08:04 PM
Does the VY 4L60e have a bolt on bell housing or the one piece?
Did you fit the factory RPN switch on the gear selector shaft?
Which engine mounts did you use?
Which prices do you think are too high?
Edited by ls2lxhatch, 21 December 2015 - 08:06 PM.
#17 _LS1 Taxi_
_LS1 Taxi_
Posted 21 December 2015 - 08:11 PM
Bolt on bell housing.
Tuff mounts.
Loom was $450 U.S. for a brand new hot rod loom.
Extractors are $900 for the shit CAE things (I modded these to fit mine). Grant bolted up factory holden commo manifolds ($50?).
Sum
My tuner charges $550 for dyno tune (can delete VATS and MAF then).
#18 neglectedtorana
neglectedtorana
  • 1,055 posts
  • Name:Tom
  • Car:LX Torana Sunbird
Posted 21 December 2015 - 08:17 PM
Either way you will end up with a great car, my concern and this probably goes for either but more for the LS1 will be keeping your beautiful engine bay beautiful
I mean not scratching it etc. Custom extractors are not gentle.
Also to consider is time. I think you are more likely to have set backs and delays with the LS1
I think I am past the hard bits of the LS1 fitment and look forward to one day driving the car with the fuel injected LS1 as I am definitely too far past the point where I could go back to the carb 308 but if I never went for the LS1 I think I would already be driving my car
Your car looks great!
#19 ls2lxhatch
  • 5,335 posts
Posted 21 December 2015 - 08:35 PM
Tuff mounts.
Sum
Last time I checked none of the off the shelf headers are worth buying, things may have changed since but I would still budget for custom headers. As you found the CAE headers are designed to fit with the CAE engine mounts and starter motor. Once you fit the lower Tuff mounts the CAE headers need to be modified.
In my opinion the CAE engine mounts are too high, the higher CAE engine mounts also cause the 4L60e to hit the top of the transmission tunnel.
$450 USD is currently $628 plus maybe $100 USD freight works out around  $770. I see CRS sell the LS1 4L60e loom for $1000 so $1200 is too high. The CRS LS2 loom is $1300.
Edited by ls2lxhatch, 21 December 2015 - 08:38 PM.
#20 _LS2 Hatch_
_LS2 Hatch_
Posted 21 December 2015 - 08:47 PM
My loom cost me closer to $1500 by memory. It's the GM Performance kit, came complete with loom, computer and fly by pedal
Custom extractors are a good idea done by the right shop. The wrong shop may rob you of HP, not increase it.
I went back through an old thread and found a quote from you Daz
"I would go EFI 308 if I was to do it again". This was before you got yours running, it was still in the build.
What are your thoughts ow the ard work is done? I guess you are a good one to answer this as you have had the 308 in another Taxi, and now the LS.
Would you do it again?
I would :)
#21 _LS1 Taxi_
_LS1 Taxi_
Posted 21 December 2015 - 09:26 PM
Good question mate.
For trouble free bang for buck HP, you can't go past the LS.
#22 _Ryno364_
_Ryno364_
Posted 21 December 2015 - 09:37 PM
Great work guys, I'm gonna go down the old skool 383 SBC road. There are definitely advantages of going down the LS road as far reliabilty, ease of making HP, light weight etc but I get the feeling it is by no means an easy conversion.
Have just attached a couple of pics   hehe
Once again thanks for all your input, will keep you posted after the SBC is in the engine bay.
#23 unclefestal34s
unclefestal34s
  • 1,130 posts
Posted 21 December 2015 - 10:27 PM
good decision
#24 _LS2 Hatch_
_LS2 Hatch_
Posted 22 December 2015 - 05:07 AM
As I said earlier, can't go wrong either way.
Good luck and I look forward to the thread. Don't let us wait for the finished product, we want to be part of the process!
Cheers Grant
#25 _LS1 Hatch_
_LS1 Hatch_
Posted 22 December 2015 - 10:43 AM
Darn, looks like I am too late to say go the LS.. ha ha..  :D
