we just put in my v8 brake booster an went to put the master on an it doesnt fit so we have to use the a9x style 1 that came with the booster but the problem is its for disk brakes does that matter?? andd wat kinda brake lines do u need for them?
mastercylinder help
_T0rana_
, Jul 31 2006 06:55 PM
3 replies to this topic
#1 _T0rana_
Posted 31 July 2006 - 06:55 PM
Posted 31 July 2006 - 09:05 PM
I think drum brakes require a certain pressure to remain in the brake line where as disks don't, I had a problem with the front brakes locking on after I fitted my disk brakes to the front of my LC while still using a drum brake master cylinder, Put a disk brake master on and it was fine as no pressure was being held in the line.
Posted 01 August 2006 - 01:03 AM
Yep. Drum brakes require a higher residual pressure for them to work correctly. You can buy inline residual pressure valves to suit your drum brakes without having to change the master cylinder.
Posted 01 August 2006 - 01:05 AM
Not required on ADR style master cylinders like COmmodore
Commodore came with drum rear and used the same master as the disc rear
