oil pressure sender unit
20 replies to this topic
#1 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 22 January 2016 - 03:58 PM
There appears to be two oil pressure sender units listed for the LJ torana with gauges. One is 0-75psi and the other is 0-80psi. Which one is correct?. I'm assuming the 0-80psi sender is correct for the LJ since the LC oil pressure gauge indicates 0-80 on the dial.
#2 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 22 January 2016 - 08:01 PM
0 - 80psi is correct for LJ GTR back in the day Holden part 7429181. Now I have a oil sender unit dated 7/1990 holden part 7429181 for LJ GTR and it has 500kpa (72.519 psi ) stamped on the side of it so Holden dropped the psi rating on them,hope info helps
#3 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 23 January 2016 - 06:01 AM
Doesn't this mean that the oil gauge will never read correctly.
#4 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 23 January 2016 - 06:29 AM
Your gauge will read short and If you have a old Holden oil pressure gauge how accurate is it after 44 years. Mate go for the 550 kpa oil send unit that = 79.771 psi That as close as you can get Today
#5 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 23 January 2016 - 06:44 AM
Any idea where I can buy one of those?
#6 RM125n
RM125n
  • 54 posts
  • Car:TORANA
Posted 23 January 2016 - 08:17 AM
Rare spare list one not sure of kpa rating or VDO they will tell where to go and E Bay .
#7 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 23 January 2016 - 10:23 AM
Do I need a sender with 1/8"-28BSBT or 1/4" -18NPTS thread ?
#8 S pack
  • 15,743 posts
Posted 23 January 2016 - 01:18 PM
Not really going to matter that much. I doubt there would be many, if any, old holden sixes that will make 80psi hot so if your oil pump can do 60psi hot the 500kpa (72psi) sender unit will still be fine.
#9 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 23 January 2016 - 03:53 PM
Thats true but I at least want the gauge to read correctly, especially if the oil pressure is low. Can you tell me which thread it is?
#10 S pack
  • 15,743 posts
Posted 23 January 2016 - 04:04 PM
I thought the thread size for the sender was 1/8" but I could be wrong, sorry I can't be more definite.
#11 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 23 January 2016 - 05:24 PM
The VDO catalogue does not list an oil pressure sender for the LC / LJ.
#12 S pack
  • 15,743 posts
Posted 23 January 2016 - 06:28 PM
The gauge should read correctly with either sender unit. The difference is one sender is capable of registering a higher pressure indication on the guage than the other. 72 psi vs 79 psi.
#13 _hutch_
_hutch_
Posted 23 January 2016 - 08:11 PM
The oil pressure gauge in my LJ  has only L and H on it,all the other gauges have numerals,never noticed it before,so is the gauge
ee wrong ?
#14 S pack
  • 15,743 posts
Posted 23 January 2016 - 09:34 PM
ee wrong ?
Phil, the oil pressure gauge without any numbers is the LJ metric gauge. Introduced into production from July 1973.
The matching LJ metric temp gauge is marked in Celsius and the speedometer is the dual scale KM/mph variety.
#15 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 24 January 2016 - 05:18 AM
Not sure I agree with you Dave. Both sender units have a working range of 0-180 ohms. This would mean that when the sender is at half pressure (90 ohms), one would read 36psi and the other 40psi. It's not much I know, but if I'm going to buy one, I might as well buy the one which will read most accurate (that is if I can get one).
#16 S pack
  • 15,743 posts
Posted 24 January 2016 - 08:01 AM
Ray
If both senders operate from 0 to 180 ohms then they both must display the same needle position on the gauge for the same ohms.
Edited by S pack, 24 January 2016 - 08:02 AM.
#17 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 24 January 2016 - 08:26 AM
yes but at different pressures
#18 S pack
  • 15,743 posts
Posted 24 January 2016 - 08:36 AM
Are both of these senders from the same manufacturer?
#19 S pack
  • 15,743 posts
Posted 24 January 2016 - 08:54 AM
Almost forgot. I found a thread On the Forum in which Dr Terry advises the thread size on the oil press sender is 1/4" NPT.
#20 rtorana1
rtorana1
  • 249 posts
  • Name:ray
  • Car:lj
Posted 24 January 2016 - 04:08 PM
Thanks for the thread size Dave. From what I can make out the original sender used was an 80psi VDO unit. Looking at the VDO catalogue the closest sender now available in the correct thread size, resistance range (0-180 ohms) and button type connection is a 75psi unit. Probably close enough.
#21 S pack
  • 15,743 posts
Posted 24 January 2016 - 04:28 PM
Dr Terry advocates the VDO sender Pt No. 360-004 is the correct replacement unit to suit the HB/LC/LJ/TA Torana, HD/HR, HK/T/G & HQ Holden with oil pressure gauge.
Edited by S pack, 24 January 2016 - 04:29 PM.
