Main issue seems to be ethanol %/octane rating varies from tank to tank sometimes too high so blokes may have to dilute fuel down then cars run sweet again as tuned for that octane rating.
Hard starting & running rich as hell usually..easily fixed with fuel tester available...obviously efi cars dont have that issue.
Gumming up is bit hit or miss depending on car & fuel system...using old factory tank not cleaned out/treated & sealed increases chance it will happen...also moisture/air getting in does it.
