Willwood master
1 reply to this topic
#1 _LH BBC 850hp_
_LH BBC 850hp_
Posted 02 August 2006 - 09:26 AM
Hi,just wonder if anyone know if willwood master is the same size as hq one? and all so wonder if i got this right i have ford rear drum brakes with hq on the front with the master in the bay i need remote booster right? which i need to put under the guard coz of room in the bay.So the master run into the the booster right? then too the brakes? .....allso what are best calipers for hq?
Any help would be great if u can understand what i wrote!
#2 Struggler
Struggler
  • 2,426 posts
  • Name:Andrew or AJ
  • Car:UC Sedan
Posted 02 August 2006 - 11:07 AM
My booster stayed in the standard location, just had to use short valve covers to make it all fit. If you have aftermarket heads you will need to move the booster. It is possible to move it over about 30mm toward the inner guard but it will require firewall surgery to reinforce the new position. I would prefer to do it this way rather than run a remote booster. Hope this helps.
