new 355 motor
68 replies to this topic
#51 Redslur
Redslur
    Has been Torana owner
  • 3,535 posts
  • Name:Gerry
  • Car:HQ GTS Replica 350.
Posted 28 August 2016 - 06:50 PM
Are you running a scoop or does this new manifold combo fit under the bonnet
If similar to the TQ D/P they dont quite fit under the bonnet.  I am running a 9x3 filter and it protrudes
about an inch out the bonnet.  A smaller filter may get it all under but will restrict air flow into the carby.
#52 _parsons5000_
_parsons5000_
Posted 28 August 2016 - 07:40 PM
I'm not sure about compression ratio I think it might be 10:7 something like that I'll have it on dyno 5 th sept with results and full specs
#53 LS1LX
LS1LX
  • 1,931 posts
Posted 30 August 2016 - 02:24 PM
running a scoop if u like i can measure height for u if ur wanting to run one
That would be great if you could measure the pad height, COME reckon there will fit under bonnet with dropped air cleaner, the last one I put on a car had a scoop
Bummer, cheers for the heads up, do you know the height of your manifold?
#54 Redslur
Redslur
  • 3,535 posts
  • Name:Gerry
Posted 30 August 2016 - 07:28 PM
Think total it was 150mm.  It is advertised on their website from memory.  A dropbase aircleaner should fit just...I didn't use one because I had a throtle bracket and a dropbase set up won't clear the bracket.
Edited by Redslur, 30 August 2016 - 07:29 PM.
#55 adgjl7
adgjl7
  • 82 posts
  • Car:lx hatch
Posted 14 October 2016 - 12:36 AM
hi looks good,was wondering if you could post a better pic of the cam specs. and is it one they recommended or did you pick it cheers.what sort of rpm range does it work with.
#56 _parsons5000_
_parsons5000_
Posted 14 October 2016 - 11:03 PM
Very happy with results . Didn't even push it past 5700 as its fresh am I'm not wanting max figures :)
#57 Lima31
Lima31
  • 874 posts
  • Name:Lee
Posted 15 October 2016 - 12:07 AM
B)
#58 Redslur
Redslur
  • 3,535 posts
  • Name:Gerry
Posted 16 October 2016 - 06:12 PM
Well done.  Now the 'having to pay for petrol' part :-)
#59 _parsons5000_
_parsons5000_
Posted 16 October 2016 - 07:00 PM
haha petrol least of my problems :)
#60 Redslur
Redslur
  • 3,535 posts
  • Name:Gerry
Posted 17 October 2016 - 11:08 AM
I was only getting about 100k's to a tank in my 500+hp 355 LOL.  I have taken it back to about 450 hp so should get 200k's a tank now LOL
#61 _Skapinad_
_Skapinad_
Posted 17 October 2016 - 02:06 PM
A tank for 100kms sounds perfectly reasonable :)
#62 gtrboyy
gtrboyy
  • 3,141 posts
Posted 17 October 2016 - 02:48 PM
Glad not just me with ordinary fuel figures Red haha
60 litre vh commodore tank was lasting 2-3 drives maybe 250 tank lots of traffic,some spirited spurts...thought was decent for 4500 stally & 4.56 gears lol
#63 LXCHEV
LXCHEV
  • 3,510 posts
  • Car:'76 LX - 383 Chev
Posted 17 October 2016 - 04:57 PM
What are the litres per 100km for you guys?
My 383 Chev (around 440HP) uses around 25 litres per 100km on the road. It's interesting hearing about the hotties, some of the figures are staggering!
#64 Redslur
Redslur
  • 3,535 posts
  • Name:Gerry
Posted 17 October 2016 - 07:29 PM
  1. Sounds about the same as mine now, Brett.  4000 converter with 3.5 gears and 450hp 355.
#65 gtrboyy
gtrboyy
  • 3,141 posts
Posted 17 October 2016 - 07:54 PM
Mine copped a lot of stop/start driving although reckon will nudge 300'ish maybe higher the more the car gets sorted cool weather/night drives dont make me look for holes in fuel tank anymore...going from diff dumpers to tailpipe improved torque...no more earplugs although 305/50/15 feel useless.
Cold air tray,hec coil & bigger alternator on wishlist of improvements.
#66 rexy
rexy
  • 3,598 posts
  • Name:Rexy
  • Car:Kia grand carnival!!!
Posted 17 October 2016 - 10:46 PM
In general suburban driving the ute uses 50 L per 100km or thereabouts. Thank god its LPG and not premium. It's a BBC with 4000 converter and 3.25 rear gears. 275/40/17 tyre.
#67 Redslur
Redslur
  • 3,535 posts
  • Name:Gerry
Posted 18 October 2016 - 11:22 AM
I used to drive my first SLR5000 as a daily with a stage 3 sort of set up 308 and was getting about 300-330k's a tank back then. That was with a 3.08 diff ratio. Would hate to be driving them as a daily nowadays :-)
#68 myss427
myss427
  • 1,636 posts
Posted 18 October 2016 - 12:09 PM
If I drive mine economically I can get 11 litres per hundred, put the foot down about 40 litres plus. Overdrives are your friend!
#69 LS1LX
LS1LX
  • 1,931 posts
Posted 21 October 2016 - 07:04 PM
Cam 241/241 0.325" lobe lift?
