what stall converter comes out stock in a trimatic with a 173 in front of it, also whats the biggest cam i would be able to put in with a stock stallie
thanx guys
james
stall converter help
_Ucmyuc_
, Aug 04 2006 02:10 PM
3 replies to this topic
#1 _Ucmyuc_
Posted 04 August 2006 - 02:10 PM
#2 _Jewboy_
Posted 05 August 2006 - 03:27 PM
Most factory stalls are upto 1800 rpm. You can use one out of a gemini which i think will take it to 2500-3000 (others on here will know better). Problem with changing cams is that you usually need to change a fair bit of other stuff from a stock motor to get the best out of it (carb, exhaust, diff ratio). If everything else is staying stock you will only be able to go up a few sizes, check out the crane cams website it will give you an idea of what the cam will be like and if you can keep the stock stally.
#3 _Ucmyuc_
Posted 06 August 2006 - 05:11 PM
with the cam i will be looking to run a WW stromie extracter with 2 inch exhaust and 3.55 gears
#4 _UCV80_
Posted 06 August 2006 - 07:20 PM
The cam hes looking at (i think). is the crow 35604
