Injected 8 in a torry
#1 _ChiaLX_
Posted 05 August 2006 - 07:41 PM
Can I just throw the heads and injection on a black motor and then meet the adr requirments for a 85 model motor OR.... do I still have to comply with the injection system emissions?
Is there much Difference between the two bottom ends?
Posted 05 August 2006 - 08:13 PM
never liked cats, more of a dog lover myself.
#3 _jap-xu1_
Posted 05 August 2006 - 08:56 PM
a hatch is bound by adr27a so yes you have to have all pollution gear that the engine had from the factory
#4 _LJ308injected_
Posted 05 August 2006 - 09:36 PM
But LJ's are non pollution anyhow use a early block and you should be right mate and if not just gutt the cat's anyway easy done.
Cheer's - Steve
Posted 05 August 2006 - 09:37 PM
The emissions controls must be the same as the engine came with.
If its a late model engine out of a VN as you say.. then Yep youve gotto do it!
IF however you retrofit an injection setup to the original block... then cats arent neccesary! It all comes down the the date when you do a search against the engine number!
#6 _Toranamuk_
Posted 06 August 2006 - 10:43 AM
It all relates to the ADR that the engine has to comply to, not what year the car is.
#7 _ChiaLX_
Posted 06 August 2006 - 12:19 PM
#8 _coupe202_
Posted 06 August 2006 - 03:45 PM
this topic is very grey.
Posted 06 August 2006 - 03:51 PM
i thought it would be black and white, as above ^^^
Posted 06 August 2006 - 05:42 PM
There's nothing 'grey' here, it's fairly straight forward.
If you have say a 1977 car, you can't fit an earlier engine, but you can fit a later engine. If you fit a later engine you must comply with the ADRs for that later engine. If you fit say a VN/VP EFI V8, there's not much to comply with. Your 1977 car already has a vapour canister & you will need the gear that comes with the EFI V8. Apart from the cats there isn't much else, it would be easier than trying to fit all the old ADR27A gear anyway.
Dr Terry.
#11 _coupe202_
Posted 06 August 2006 - 06:24 PM
Posted 06 August 2006 - 06:31 PM
^^^^^^^^^^Tiny's correct,
#13 _Keithy's_UC_
Posted 06 August 2006 - 07:05 PM
Keith
Posted 06 August 2006 - 07:13 PM
carefull with cam lift and 253 for valve to bore clearence.
#15 _jap-xu1_
Posted 06 August 2006 - 07:15 PM
you are not totally correct.Tiny's correct,
pre 72cars dont have to comply to this adr as i have already stated
#16 _Herne_
Posted 06 August 2006 - 08:10 PM
What I do have to do though is present the car at the engineers (again) and he will ammend my engineering certificate (a fee apply's) and then present the car over the rego pits here and another fee apply's
Seems everyone has their hand in your pocket when it comes to conversions and rego.
Herne
Posted 06 August 2006 - 08:29 PM
finnally canberra comes up with the goods
#18 _Toranamuk_
Posted 06 August 2006 - 08:47 PM
The engine year is simply taken from the engine number (from this people should be able to work out what to do to suit them).
If you fit a ADR 37 engine to an early you are required to fit cat converters & a carbon canister.
If you use an early block to replace a late model block you are required to supply a statutory declaration to the rego authority stating that all parts used in the reconditioning process are compliant for the year of the engine, & that it will meet the appropriate ADR requirements.
They assume if you are a late engine number in an early vehicle then you have also fitted the correct ADR components to go with the package.
It all goes by the engine number so if you deck the block then there's no engine number & a new replacement number can be issued by the appropriate people.
The rego authorities do'nt use engine casting date codes.
A bit of reading between the lines will answer some queries.
Posted 06 August 2006 - 08:49 PM
#20 _Yella SLuR_
Posted 06 August 2006 - 09:19 PM
#21 _Toranamuk_
Posted 06 August 2006 - 09:41 PM
MOST rego authorities now do not enforce this, as now all you can purchase is unleaded fuels at commercial retail outlets (servo's).
Saves us some extra work on a common conversion.
#22 _Keithy's_UC_
Posted 07 August 2006 - 06:57 PM
Keith
#23 _Herne_
Posted 07 August 2006 - 07:29 PM
Pat, first thing I did was check with Gerry who then checked with his boss. I believe I am right in this instance for the ACT.I believe Toranamuk is correct. Al, may pay to ask the exhaust dude when you get your exhaust fitted up. For your sake, I hope you don't need em, cause even the generic units are $330 each.
Thats all I am gonna say on this.
Herne
#24 _Yella SLuR_
Posted 07 August 2006 - 07:49 PM
Unfortunately the engine conversion regs are pretty consistent across Australia.
Edited by Yella SLuR, 07 August 2006 - 07:57 PM.
#25 _Yella SLuR_
Posted 07 August 2006 - 10:31 PM
