LH rear seat base
#1 _L31SLR_
Posted 06 August 2006 - 02:24 PM
Can anyone tell me if there are supposed to be hooks on the floor where the rear of the back seat mounts to retain the back of the rear seat base?(I am not talking about the seat back but the back/rear of the seat base!!?? Confused yet!!??)
I can see that the seat slips fairly tightly over the box section at the front and is then screwed through the bracket making the seat really well mounted at the front but the back/rear of the base moves around and sought of pivots and flexes when an adult gets in and out of the back seat.
If there are hooks or retainers can someone please take a picture of them and where they are mounted so I can try and find out what happened to mine!
Cheers again
L31SLR
PS Is there supposed to be spacers where the seat back is bolted to the floor with the seat belt brackets so the seat back comes out further and holds the back/rear of the seat base in?
Posted 06 August 2006 - 02:51 PM
Posted 06 August 2006 - 03:04 PM
the rear of it slips down under the 'squab' and is pressed in at the front (sort of a resistance fit), and then held down with the two screws
dave
Posted 06 August 2006 - 03:16 PM
The seatbelt restraint bolts yes?the rear of it slips down under the 'squab' and is pressed in at the front (sort of a resistance fit), and then held down with the two screws
The Seat has to be removed when the Squab is installed so that you can get access to those two bolts that also restrain the Seat Belts.
I've never seen a Seat actually screwed/bolted in to be honest. I've only seen the seats sitting on there. They do tend to move around a tiny bit but it doesn't overly bother me.
At the end of the day, nothing has to be bolted down. My car was pretty boganized by the last owner, but I mean it was still used as a family car. Anyway, I literally pulled my rear seat & squab out in about 20 seconds and I didn't even know what I was doing.
The only 'hooks' I can picture are the ones that hold the squab in. You need to lift the seat up and it will pop off those hooks.
If you want any pics of something, I've got no interior atm so just ask.
Edited by Heath, 06 August 2006 - 03:17 PM.
Posted 06 August 2006 - 03:40 PM
Posted 06 August 2006 - 04:36 PM
In that case I should probably find some screws for the seat. Don't even know what I'm looking for lol.
#7 _Yella SLuR_
Posted 06 August 2006 - 07:21 PM
If anybody know's how to bend, wrestle, etc. to get these sections in to the tube section bits, I'm all ears. Might actually have a read of the manuals/parts books see if they are bent or something.
Can totally relate the to the seatbelt muching rear seat. Damn annoying.
#8 _L31SLR_
Posted 06 August 2006 - 09:54 PM
L31SLR
#9 _Yella SLuR_
Posted 06 August 2006 - 10:17 PM
Will have bit of a read tonight and report back.
I'm not going to attempt mine again till summer when the weather is warmer, and the days longer. I get the feeling from my experiences that once they stop being fitted to the hooks/tubes/fitting, then the spring steel starts springing beyond the point of no return. I hope not.
Keep us informed of how you go, I'll do the same.
#10 _50SLO_
Posted 09 August 2006 - 09:23 PM
Unfortunatly I cant seem to find a pic of the actually seat it self. If I find it I'll post it up.
#11 _Jewboy_
Posted 09 August 2006 - 09:43 PM
#12 _50SLO_
Posted 10 August 2006 - 01:21 PM
