Celcia Box into LC/J Torana
#1 _73LJWhiteSL_
Posted 06 August 2006 - 10:21 PM
Has anyone got some pics of the Celica 5 speed in a LC/J Torana? Mate reckons it won't fit inside the transmittion tunnel.
Steve
#2 _@milco@_
Posted 06 August 2006 - 10:45 PM
#3 _73LJWhiteSL_
Posted 06 August 2006 - 10:48 PM
I assume you are in Melbourne, i was wondering if I would be able to drop around and stick my head under your car and have a look if possible?
Steve
#4 _@milco@_
Posted 07 August 2006 - 01:47 PM
#5 _73LJWhiteSL_
Posted 07 August 2006 - 06:07 PM
Steve
#6 _LC2250_
Posted 14 August 2006 - 10:56 AM
Just wondering what you've done about the tailshaft? It's not the original LC/LJ one is it?
-Al
#7 _RpM_
Posted 14 August 2006 - 11:35 AM
#8 _73LJWhiteSL_
Posted 14 August 2006 - 03:43 PM
The setup came out of a LX Hatch, so I will measure the tailshaft and record how long it needs to be for the LH/X/UC Toranas, then hopefully when i get a look at @milco@s Torana i can measure his and see if the same tailshaft fits or it needs to be shorter.
I am planning to write a tech article with pics when i do this, so hopefully you guys will have something to look at.
Steve
#9 _LC2250_
Posted 15 August 2006 - 11:35 AM
Aren't there a few different types of gearboxes with the shifter in different locations (ie, slightly closer to the back or the front). Is there a specific one that is right for the hole thats pre-cut into most of our trans tunnels?
edit: oh on another note ... does anyone know if the standard crossmember fits or with mild adjustments?
-Al
Edited by LC2250, 15 August 2006 - 11:36 AM.
#10 _draglc_
Posted 15 August 2006 - 03:32 PM
On some there is a bit that sets the shifter back about 6 inches... my box had that when i got it, but you can just unbolt it and put the shifter back in the original spot. Bit of mucking around, but easy enough to do.Aren't there a few different types of gearboxes with the shifter in different locations (ie, slightly closer to the back or the front). Is there a specific one that is right for the hole thats pre-cut into most of our trans tunnels?
After doing that, the shifter is just about exactly the same as m20 shifter hole.
A1
#11 _73LJWhiteSL_
Posted 18 August 2006 - 10:06 AM
This is part of the reason I posted this, does anyone have pictures of the crossmember or a modified one?edit: oh on another note ... does anyone know if the standard crossmember fits or with mild adjustments?
Steve
