bmw rods holden 6
#26
Posted 25 September 2016 - 08:04 PM
Disappointed.....
#27
Posted 25 September 2016 - 08:37 PM
Sorry Mate,
Need to select all the great forum Member goodies,
aka 5.71 rods
still can fail, but will test out the big bang, again and again
Edited by N/A-PWR, 25 September 2016 - 08:41 PM.
#28
Posted 25 September 2016 - 08:39 PM
15::1 pmslDave won't be using bmw rods in his 15:1 n/a 400hp street engine then?
Disappointed.....
#29
Posted 25 September 2016 - 09:30 PM
Agree with johno tho, with whats out there, weight would be the reason to run them.
There are some VERY nice aftermarket bmw rods out there but cost more than a good set of rods for a small block chev.
#30
Posted 25 September 2016 - 09:41 PM
#31
Posted 25 September 2016 - 10:09 PM
bmw rods are 90-100 grams lighter than standard/starfire rods once protrusion is removed from big end,id say that was significant enuff.and longer.12 thou wider on big end so either rod is narrowed or crank widened.id go with the wider crank as they need regriding anyway when rebuilding.would be a cheap alternative
#32
Posted 25 September 2016 - 10:13 PM
#33 _ljxu1torana_
Posted 25 September 2016 - 10:36 PM
The big dick hanging down the bottom of the m30 rods interests me.
well davey at least you admit that you like dicks.
#34
Posted 26 September 2016 - 04:43 AM
Oh my god, pmsl! Jason actually got one back!! thanks.
Edited by I'm a Red Motor fiend, 26 September 2016 - 04:46 AM.
#35 _ljxu1torana_
Posted 26 September 2016 - 04:54 AM
davey likes wolly moofs.
#36 _STRAIGHTLINEMICK_
Posted 26 September 2016 - 08:49 AM
I think we need to remember that when people first started using rods like those from BMW there was no such thing as the blue/black/Starfire rod that later became so cheap and easily available. These days there's probably not much point in spending time on something that isn't significantly lighter or longer than the blue/black.
Exactly right johnno.the bmw rod is only 1.5mm longer than the holden ,How much interest would there be from racers and people on this forum if i were to get some h beams made that were 13mm longer ,stronger than starfires ,took an off the shelf piston and were a bolt in fit.
#37 _ljxu1torana_
Posted 26 September 2016 - 10:52 AM
is about 100 grams or so is going to make any difference?
#38
Posted 26 September 2016 - 11:33 AM
That 100g would become how many kilos of rotational force at 7000rpm?
A shitload I reckon. It would be taking a fair bit of load off the crank/bearings & block.
#39
Posted 26 September 2016 - 11:51 AM
#40 _STRAIGHTLINEMICK_
Posted 26 September 2016 - 11:53 AM
Someone a little more clued up on newton's laws could do the maths.
Yep shitloads
#41
Posted 26 September 2016 - 11:54 AM
#42
Posted 26 September 2016 - 11:57 AM
depeds what bmw rod you use there are quite a fewExactly right johnno.the bmw rod is only 1.5mm longer than the holden ,How much interest would there be from racers and people on this forum if i were to get some h beams made that were 13mm longer ,stronger than starfires ,took an off the shelf piston and were a bolt in fit.
#43
Posted 26 September 2016 - 12:09 PM
The problem with selecting beemer rods, or I guess any other manufacturers rods, is its hard to "just go & have a look at them" if you know what I mean. Not everyone will have an engine stripped to inspect.
#44 _ljxu1torana_
Posted 26 September 2016 - 03:54 PM
and what is it with all the stupid comments about dicks etc,it is a questionare about bmw conrods nothing more.take the stupid comments to private msg
davey said that the big dicks hanging down the bottom interested me.so he must be a wolly moofs a shirt lifter pillow biter,pick up the soap in the shower and starring in his own gay porn movies.
#45
Posted 26 September 2016 - 05:17 PM
Would be good for a stroker setup maybe?
Thoughts Mick?
Edited by SA EH, 26 September 2016 - 05:19 PM.
#46
Posted 26 September 2016 - 05:37 PM
you need to spend more time trying to get your car goingdavey said that the big dicks hanging down the bottom interested me.so he must be a wolly moofs a shirt lifter pillow biter,pick up the soap in the shower and starring in his own gay porn movies.
#47 _STRAIGHTLINEMICK_
Posted 26 September 2016 - 05:48 PM
Alternatively you could go a set of e34 M5 s38 straight 6 rods if you can find a set. They are identical specs to the m30 rods but the length is a longer 5.670".
Thoughts Mick?
All depends on crankpin sizes and how many mods are reqd vs
the cost of new rods.
I started with leyland 1275 rods which worked well but the cost of modifying these was close to the cost of new h beams with 3/8" bolts . Obviously new rods are the better choice and easier to sell.
#48 _oldjohnno_
Posted 26 September 2016 - 06:55 PM
About 226kgf.
The important part is the reciprocating weight of the rod - the rotating part can be completely cancelled out by the crank counterweight so it doesn't cause any problems at all. It's the up-and-downy bit that's the troublemaker.
#49 _oldjohnno_
Posted 26 September 2016 - 07:01 PM
Quad 4 rods are 11 - 12mm longer, have a bushed small end and damn near bolt in. No lighter though.
#50
Posted 26 September 2016 - 07:16 PM
Everyone is different so you will still get old mate down the road machining in some bmw rods while you go & buy yourself some spool rods & throw them in.
