as some of you blokes know ive recently bought a lh which im close to installing a 253 trimatic
just wondering if hq ones will fit or commodore stock exhaust manifolds
if not anyone got a cheap set of lh lx ones
also will a 6 cyls traumatics linkages and speedo gear fit onto a v8 one?????????
lh exhaust manifolds
_chevy_253_torana_
, Aug 07 2006 09:30 PM
3 replies to this topic
#1 _chevy_253_torana_
Posted 07 August 2006 - 09:30 PM
#2 _oikurtman_
Posted 07 August 2006 - 10:21 PM
recently did this one myself...
as for the manifolds i'm pretty sure you will need a torana one for the passenger side, but i had extractors so yeah.
the linkages depends on what your traumatic is out of. torana shift linkages are on the drivers side, but commodore shifters are on the passenger. have a look before you throw the box in. if the shift on the box is the opposite to the car, the shifter can be rebuilt back to front and the problem is easily solved.
if your going from 202 auto you will probably need to take the white gear off the end of the speedo cable and replace it with a "blue" one? thats what i did but mine was a commodore box. have a look inside the cable seat and see what colour the speedo gear is in the box. mine was blue so i used blue on the cable as well.
cheers.
cheers.
Posted 08 August 2006 - 11:03 AM
keep the same speedo gear as whats already in the car, unless you are changing the diff gears.
#4 _UCV80_
Posted 08 August 2006 - 01:16 PM
i have a pair of LH v8 stock exhuast headers that i will part with
speedo and shifter will 100% fit, the v8 trimatics are bacically identical to the 6 externally. both have same final 1:1 ratio so cog colour wont need to be changed
,nathan
,nathan
Edited by ToranaZ, 08 August 2006 - 01:22 PM.
