Guess what's on again!
#176 _76lxJAS_
Posted 04 February 2017 - 11:53 AM
Apparently it was legal to have no bonnet?
#177
Posted 04 February 2017 - 12:00 PM
Hotrods don't have to use a bonnet
#178 _76lxJAS_
Posted 04 February 2017 - 01:15 PM
#179 _LHSL308_
Posted 04 February 2017 - 04:32 PM
So if you can get away without having a bonnets how can hornet scoop he illegal and reverse cowl not be?
I had a friend years ago who used to run his Torana without a bonnet also. He used to have a bug catcher sticking out of the bay. Back in the day I don't think it was illegal but these days I'm pretty sure it is.
I'm not sure why a hornet scoop is illegal and a cowl scoop isn't, seems a pretty stupid rule if you ask me but I'm sure there's a stupid reason for it. Last I heard it was because a letterbox style scoop can cause more serious injury when hitting a pedestrian or something to that effect. I'm sure there is a height limit on what cowl scoop you can run also.
Here's the vicroads guide for modified vehicles. I'm sure it's in there somewhere.
http://tomcc.com.au/...or-vehicles.pdf
Then it goes onto refer to VSI29 for more technical BS.
Edited by LHSL308, 04 February 2017 - 04:48 PM.
#180
Posted 04 February 2017 - 05:18 PM
The reason you can't run a car without a bonnet, or with a reverse cowl scoop that isn't sealed around the carby with an open back (ala A9X) is if you lose coolant or oil from your motor it ends up on the windscreen. I turned up at Ravenswood Raceway (drags) back in the late 80s without a bonnet and was told it wouldn't pass scrutineering.
#181
Posted 04 February 2017 - 05:46 PM
And the reverse cowl tends to allow them roll off?
An open engine bay is illegal for the same reason as the fwd opening scoop.
Someone somewhere decided it would be safer etc.
Sane reason cowl mounted gauges and superchargers out the bonnet are illegal.
So thats why reverse cowl scoops are so popular. People want to driv on the street legally and without hassles so they fit them to satisfy the engineer signing the car off.
#182
Posted 04 February 2017 - 06:52 PM
"NCOP6_Section_LH_Body_and_Chassis" (page 12) says:
For vehicles manufactured prior to 1 July 1988, there are no specific design rule requirements
relating to bonnet scoops. However any such fixture that is a dangerous protrusion or obstructs thedriver’s forward view of the road, is prohibited by both the ADRs and AVSR.
For vehicles manufactured on or after 1 July 1988, ADR 42/... prohibits external or internal protrusions
that are not technically essential and are likely to increase the risk of bodily injury to any person.
Rigid engine-mounted components that are likely to increase injuries to a pedestrian in a collision mustnot project through and above the vehicle’s original bonnet profile, unless protected with a cover
mounted to the bonnet.
Although some "Hornet" style scoops are perfectly legal.
The official test (from NCOP6):
It also goes on to say that:
Holes may be cut in the bonnet to allow the protrusion of an air cleaner or carburettor
above the bonnet line providing the protrusions remain underneath the bonnet scoop.
In these circumstances, the bonnet scoop or raised bonnet section must be
manufactured from mild steel of equivalent gauge to that of the original bonnet;
So most of these fibreglass/composite scoops would still fail anyway.
#183
Posted 04 February 2017 - 08:27 PM
Mates car has steel bonnet and fiberglass scoop and passed all tests and is 100% legal.
#184
Posted 04 February 2017 - 08:44 PM
Hate the look of reverse cowl scoops even silly brock scoop on my tubbed sle BUT it's probably why it doesn't get pulled over otherwise I'd have offensive 9x5 aircleaner clear out the bonnet.
#185 _LHSL308_
Posted 04 February 2017 - 10:07 PM
Yeah me too. I can't stand a reverse cowl on a newer Commodore. Everytime I see one I just think what was the owner thinking, obviously not much.
#186
Posted 05 February 2017 - 07:19 AM
What if the bonnet is made of fibreglass? I believe this is the case with most of the ribbed scoops, you replace the bonnet rather than tack on a scoop.
s
#187
Posted 05 February 2017 - 09:58 AM
How many fibreglass bonnets have been tested to ensure they don't have an impact on crumple zones and air bags and the like? My guess is that these would be illegal as well.
#188
Posted 05 February 2017 - 10:11 AM
How many of the cars with them have airbags? lol
I get what you're saying and the engineer would approve it to the same regs as the year of manufacture.
One absurdity, you don't need rear seatbelts in some cars from the 60's but they won't pass you if you have US seatbelts in the rear, they'll tell you to remove them and then pass you with no belts.
s
