Hey all.
I have this sump that I picked up today from a mate, that apparently suits a 308 into LC/LJ. Nooow, the problem I see is, is it doesnt look like it will hold enough oil.
I have been told that the more predominant design for this is to be a bit deeper at the back end, or with a duel pick up? (if thats just rumour or not, im not sure).
This one was just cut and welded, and I will re-weld + grind and dress up a bit before using if it will work. What is your opinion? Do you think it is a goer, or a thrower?
308 into LJ Sump
_RpM_
, Aug 09 2006 11:08 PM
7 replies to this topic
#1 _RpM_
Posted 09 August 2006 - 11:08 PM
#2 _rorym_
Posted 09 August 2006 - 11:18 PM
Put it on Ebay and get a Hi Energy sump from American Auto Parts.. with pick up....then you wont lunch your $5000 engine...cheap insurance...I run one...never had a hiccup...over fill it by .5 litre..total...5.5 litre....
Posted 10 August 2006 - 11:23 AM
As Rory said sell that one & get the best one you can afford high energy sump as it's not worth risking an engine when there is a much better product for a few hunderd bucks more.Star Performance is much cheaper if you have a good exchange sump.
#4 _RpM_
Posted 10 August 2006 - 10:13 PM
Thanks guys, I rang American Autos today, and they want a bit over $300 for the Hi Energy one (Do you know if they're baffled?)
And where do I contact Star Performance? Who are they?
Posted 10 August 2006 - 11:38 PM
Rocket Industries.It is the place I normally end up going to as he tends to be a little bit cheaper but usually willing to help out.It is located at Regatta Rd.Five Dock.
In mine I have the Eliminator Pan,good quality & well designed.
here is a link to show high energy pans
#6 _RpM_
Posted 11 August 2006 - 08:42 AM
Excellent, thanks mate! I will look into it!
#7 _rorym_
Posted 12 August 2006 - 02:45 PM
Go with the SuperPan, totally baffled with crank sraper as well as pick up....the best...by the way...the dipstick on your other one is on the wrong side...just FYI.
Edited by rorym, 12 August 2006 - 02:47 PM.
#8 _RpM_
Posted 12 August 2006 - 08:24 PM
Hahaha ok, thanks mate...100% wont be using that one anyway, but thanks! I didnt realise how expensive a sump was. I mean, i didnt expect it to be dirt cheap, but sheeesh...the dipstick on your other one is on the wrong side...just FYI.
