Has this been Done and how would you go about it would injected 5 litre injection setup fit I don't know much about them so need some opinions Pics would also be great , Thanks Guys
Fuel Injected 253 4.2l
_caseyo69_
, Aug 10 2006 08:40 PM
6 replies to this topic
#1 _caseyo69_
Posted 10 August 2006 - 08:40 PM
Posted 10 August 2006 - 08:57 PM
why not just fit the whole motor, new or old block.
if not then a healthy cam would support a 253 but valve to bore clearence would be an issue.
not much of an advantage here as the heads mat be too big for a streeter 253 and you would get better ecconomy and more performance from fitting a 465 holley with a matched cam.
other ways would be fitting an over the counter holley system but again cost would see you fitting the 465 holley.
P.S if you were super keen to fit the 5L inj to 253 you could stroke it to 310 which would be more than worth it(cost aside).
Edited by ALX76, 10 August 2006 - 08:59 PM.
Posted 10 August 2006 - 09:00 PM
I think its 253ToranaSS, has an injected 253 Stroker in his Hatch...
RIM
RIM
Posted 10 August 2006 - 10:35 PM
I dont think so RIM.. i think its carby!
Injection is just another way of getting the fuel into the engine! Would be easy to organise to inject a 253.. its basically just injectors into the manifold and a throttle body instead of the carby!
It could be done!
It could be done!
#5 _Herne_
Posted 10 August 2006 - 10:43 PM
I just did it, remember lol
Herne
Herne
Posted 10 August 2006 - 10:45 PM
So its Herne that has the Injected LX
I new it was an Orange one.
RIM
RIM
Posted 10 August 2006 - 10:50 PM
injection is a little more than just drilling holes and sticking in injectors as the whole principle of injection upgrade is to achieve better fuel atomisation and control by placing the injector as close to and facing the back of the inlet valve as practicle and if this cannot be achieved especially with sequencial triggering then you are onlt going backwards.
