Coxhead Banjo Diff Setup Tools
6 replies to this topic
#1 v6 torana
v6 torana
  • 494 posts
  • Name:Peter
Posted 07 April 2017 - 02:00 PM
Before I attempt to sell, can anyone advise if these tools are to setup Holden Banjo diffs ?
Attached File  IMG_2020.JPG   249.6K   6 downloads
Attached File  IMG_2022.JPG   281.6K   2 downloads
Attached File  IMG_2023.JPG   236.88K   3 downloads
Attached File  IMG_2024.JPG   236.26K   2 downloads
#2 RallyRed
  • 7,841 posts
Posted 07 April 2017 - 04:56 PM
...not totally sure....but I think you are correct.?
They had exactly that at Charlie McCarron's auction last year.
I had a look at the catalogue for you, but I think it was just called "Holden Specialist Tool""....I remembers asking someone what it was? and they said it was for setting up diffs.....but they were just a random punter...so no guarantee there.
#3 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 08 April 2017 - 06:26 PM
They certainly look the same as the ones used in the HK shop manual , one is a dummy pinion shaft , the other is an arbor for setting
pinion height , just the part #s differ probably because GMH used their own part and #s or Coxhead made the jigs for GMH and the one shown is for another application ?
Shop manual #s.
Dummy pinion shaft 4A32-1
Arbor 4A32-2
Pulley , bearing pre-loading 4A32-3
#4 v6 torana
v6 torana
  • 494 posts
  • Name:Peter
Posted 09 April 2017 - 02:44 PM
Thanks for the info.
#5 EunUCh
EunUCh
  • 2,761 posts
  • Car:japos
Posted 10 April 2017 - 02:37 PM
A litte more info. had a look in the FB & FE series shop manual and both manuals have the same two numbers as  those in pictures except the dummy pinion # not pictured.
Dummy pinion 4A30-1
Arbor              4A30- 2
Pully               4A30-3
Not sure if that's any help or if they would be the same tools for the later bangos ?
#6 v6 torana
v6 torana
  • 494 posts
  • Name:Peter
Posted 11 April 2017 - 01:17 PM
Dummy pinion 4A30-1
Arbor              4A30- 2
Pully               4A30-3
EunUch
Thanks for the info, I have taken a picture of dummy pinion (matches your part#). I think I can now assume the tools are for a holden banjo diff setup. If anyone is interested in buying please send me aPM(sydney nsw).
Attached File  IMG_2048.JPG   182.3K   0 downloads
#7 LJ RB30
LJ RB30
  • 974 posts
  • Name:Trevor
Posted 11 April 2017 - 08:40 PM
Shop manual #s.
Arbor 4A32-2
^^^^ same numbers as I'm in LC manual
