Dual Exhaust mounts
Posted 17 May 2017 - 10:13 AM
#2 _76lxJAS_
Posted 17 May 2017 - 11:26 AM
I just got a old lh mount with a quick cut bend and weld turns into a rh mount no hassles at all.
Posted 17 May 2017 - 12:00 PM
My LH is a factory 6 cylinder and yes it has the provision for the mounting bracket
Posted 17 May 2017 - 03:18 PM
Rares sell them also.
Posted 18 May 2017 - 05:14 PM
Also on E BAY
Posted 18 May 2017 - 06:09 PM
As in if someone bought a car with L32 or L31 tags detached, how could you partially say with some degree of confidence that those tags may have belonged with that body.
Posted 18 May 2017 - 07:24 PM
Brad, my LH SLR 3300 had 'Pre-drilled Holes' in the Body/Chassis from Factory. When I fitted a 308 in 1978 the Right-Hand Muffler Hanger Bracket bolted straight on - mine is an April 1974 Model.
Posted 19 May 2017 - 11:44 AM
I think most people replying are getting confused with the holes for the rear hanger in front of the diff, im taking it your talking about the hole in the RH rear rail for the tail pipe mount?
If so Ive only seen the thread in the rail (spot welded nut) on factory dual exhaust cars
