Has anyone fitted a commodore 6cly radiator into an LJ with a 6cly. If so what top and bottom radiator hoses did you use and which water pump did you use the short or the long snout. Also what type thremo fans where used.
COMMODORE RADIATOR INTO LJ
_coupe202_
, Aug 15 2006 07:46 PM
4 replies to this topic
#1 _coupe202_
Posted 15 August 2006 - 07:46 PM
Posted 16 August 2006 - 12:46 PM
they do fit, but I am unsure of what hoses you use, maybe the standard ones?
#3 _@milco@_
Posted 16 August 2006 - 09:14 PM
i guess you would use commo 6 cly hose as they would line up to the radiator,
Posted 20 August 2006 - 02:50 PM
this is what im planning to do also......at least i now know what some of the info is so far....
#5 _dave720gtr_
Posted 20 August 2006 - 07:50 PM
cheap alloy radiator is to buy a vn commo or any new alloy one that fits and remover the plastic tanks grind all the tags off that hold the tanks on , then make up biger alloy tanks tig them on then you can have the pipes were you want
