Lowered suspension
4 replies to this topic
#1 123OUC
123OUC
  • 63 posts
  • Car:UC Torana
Posted 09 February 2018 - 10:42 AM
SO I have read that others have used Camira springs to lower the rear by 4" or so. I was just wondering weather they were Camira Lowered springs or standard?, any particular model Camira? and what springs are used for the front to achieve the same result?
Cheers in advance
#2 ozyozyozy
ozyozyozy
  • 952 posts
Posted 11 February 2018 - 10:18 PM
If you want to lower by 4 inches, might aswell just take the springs out run on bump stops.
Can fit a coil over type platform to the rear and use a generic 2.5 inch ID spring.
The front only has about 6 inches total travel and
If you use shorter length springs in rear, you will need to shorten rear shocks to stops the springs falling out at full extension.
Edited by ozyozyozy, 11 February 2018 - 10:19 PM.
#3 madtoranajzedded
madtoranajzedded
    Sir ask alot
  • 2,893 posts
  • Name:Maz
  • Car:72 LJ SL SEDAN.
Posted 12 February 2018 - 01:01 AM
Maybe some 2 1/2 drop spindles could work
for front then use small dia tire..
Will you b able to drop it at rear 4" with a
Std tubb.
#4 LXCHEV
LXCHEV
  • 3,637 posts
  • Car:'76 LX - 383 Chev
Posted 14 February 2018 - 08:56 PM
This thread may be of interest to you....
http://www.gmh-toran...d-rear-springs/
Personally, I've always used the Commo IRS rear springs - not quite as low as the Camira ones, but still very low....
#5 myss427
myss427
  • 1,636 posts
Posted 15 February 2018 - 07:46 AM
4 inch drop at the rear would give you bugger all suspension travel, inch or two at most.
