Lc/J full drag setup untubbed
6 replies to this topic
#1 Anthony
Anthony
  • 17 posts
  • Name:Anthony Raiti
  • Car:LC 4 door
Posted 25 March 2018 - 10:58 AM
I'm just wondering what setup people have in there cars, I've looked through the forum but have not seen setups with coilovers, etc untubbed, just full rear clips, I'm curious to see how far you can go with the susspention without cutting the car up as I'm almost up to buying all my susspention components.
#2 Anthony
Anthony
  • 17 posts
  • Car:LC 4 door
Posted 25 March 2018 - 11:34 AM
This doesn't exclude front setup but it's pretty self explaitory there apart from a new fabricated crossmember.
#3 _duggan208_
_duggan208_
Posted 26 March 2018 - 11:40 PM
I just beefed up what's already there. Tubular adjustable trailing arms, adjustable Spax shocks, big springs in the standard position, can't remember what they are, big fat sway bar and a panhard rod. A V8 chassis kit to reduce the body flexing. i want to eventually get some tubular upper and lower control arms, the same Spax shocks as the rear, big fat sway bar, big springs, a V8 cross member kit. I'm going to try to get a bit of weight out of the front cross member and may have a look at some stub stiffiners. I'll also have to drill out the upper control arm mounting points one inch lower same as the XU1. That's about it.
regards
#4 Anthony
Anthony
  • 17 posts
  • Car:LC 4 door
Posted 30 March 2018 - 08:38 PM
regards
Cheers for that, more so looking to see how far you can take the susspenion with the factory pickup points with the exception of coil overs.
What times have you run?, I'm guessing you have a Duggan headed holden 6 by your name.
#5 Anthony
Anthony
  • 17 posts
  • Car:LC 4 door
Posted 30 March 2018 - 08:39 PM
regards
#6 gtrboyy
gtrboyy
  • 3,141 posts
Posted 31 March 2018 - 03:52 PM
Most cars will get away with stockish springs/shocks & adjustable rear trailing arms...depends on what rear tyres used & power level car is at then decide how far you want to go.
Most can crack 11's with basic setups & 235/60 tyre
#7 _duggan208_
_duggan208_
Posted 03 April 2018 - 01:10 AM
No quarter times yet still putting the engine together. Yes I have an earlier Duggan head different to the later heads.
regards
