UC geometry question
4 replies to this topic
#1 sgo90
sgo90
  • 17 posts
Posted 27 March 2018 - 10:15 PM
Does the centreline of the stub axle line up with the centre of the lower ball joint on a UC front end?
Or is it located further back?
I need to take some measurements and it would be easier to run a string line through the ball joint if that lines up with the stub axle positions?
#2 rodomo
  • 17,999 posts
Posted 27 March 2018 - 10:19 PM
Does the centreline of the stub axle line up with the centre of the lower ball joint on a UC front end? NO
Or is it located further back? YES
#3 axistr
axistr
  • 1,169 posts
Posted 28 March 2018 - 06:08 AM
The only difference between Lh, Lx and Uc is the Uc top control arm ball join is set back 1 1/2 degrees more. The stub axle and ball joints are the same. Only the top control arm is different.
#4 axistr
axistr
  • 1,169 posts
Posted 28 March 2018 - 07:51 AM
The top and bottom ball joints and stub axle have the same centre weather its LH,LX or UC.
#5 sgo90
sgo90
  • 17 posts
Posted 01 April 2018 - 05:23 PM
Thanks for the info, cheers.
