Alternator pulley
29 replies to this topic
#26 ewe-one
ewe-one
  • 122 posts
  • Car:LJ
Posted 28 December 2023 - 05:16 PM
Came across another post where Anthony (Cabba67) mentioned he has a 2825481 629 212 45A on this 8 72.  Not sure if he still visits this forum but I wonder if his alternator is from factory.  If it is then the 45A was used earlier than an LH.
BTW, does 30A/45A refer to the current capacity in amps or just a coincidence?
#27 yel327
  • 13,720 posts
Posted 28 December 2023 - 05:47 PM
I have the LJ Engineering Technical Specs, all revisions from first release including August 1973. There is no alternator listed other than 35A. So my guess is the 30A and 45A are not current related unless they are at different alternator rpm to what GMH rate them at (4650 for Bosch, 4460 for Lucas).
#28 rodomo
  • 18,051 posts
Posted 28 December 2023 - 10:05 PM
Pretty sure i've read this somewhere?
#29 ewe-one
ewe-one
  • 122 posts
  • Car:LJ
Posted 29 December 2023 - 05:19 PM
If I was more observant the parts cat actually lists the alternator for a 4 cyl as either 629 212 40A or 629 212 40B so obviously A doesn't refer to amps.  Those I'm still at a loss as to the difference and whether a 45A was used in the LJ's.  A 73 S I dismantaled years ago had a 30A but this was NZ assembled so can't rely on this being correct for Aust build vehicles.
Does the tech spec just specify the charging current at 35A for the Alternator and not the model / type of alternator?
#30 yel327
  • 13,720 posts
Posted 29 December 2023 - 05:40 PM
Attached File  D-22 August 1971.jpg   69.54K   7 downloads
Attached File  D-22 October 1972.jpg   75.74K   3 downloads
Attached File  D-22 August 1973.jpg   90.29K   3 downloads
