Hi guys,
I have bought a rotessorie to mount my 2 door LC on like the one below and it should be delivered tomorrow.
What's the best way to mount the shell?
Does anyone have any photos of one mounted?
Posted 23 April 2018 - 01:19 AM
Posted 23 April 2018 - 07:00 PM
front bumper mounts made a cross bar with flats to bolt to chassis rails
, back mounts and my own bracket fitted to the boot latch plate
Posted 23 April 2018 - 10:26 PM
Put the rotisserie together tonight.
My car hasn't had a bumper on it since I've had it so I just wanted to check that these are the right holes?
The front ones are threaded but there rears aren't.
I'm a bit worried about how they will hold the weight.
I'm thinking I can drill holes in the right position on the rotisserie then as I can't quiet get the cross bar flush with the car, I'd use long slots and put a sleeve over them to fill the gap and make it so I can get them tight.
Posted 24 April 2018 - 02:13 AM
Posted 24 April 2018 - 02:21 AM
Posted 24 April 2018 - 09:06 AM
That's great! Thanks for sharing the photos madtoranajzedded.
I'll try and copy something similar. It'll be a good way for me to work on my welding skills at the same time.
Posted 25 April 2018 - 08:33 PM
I made my front bracket today.
Nowhere near as nice as yours madtoranajzedded but it is actually my first real attempt at welding.
I used square tube to go inside the frame of the car and it will be bolted to the inside of the brackets for the rotisserie.
It then bolts into the holes for the bonnet latch
It turned out pretty well and I'm happy with it.
Posted 25 April 2018 - 08:57 PM
Gatti, you're doing a great job with the rotisserie. If it helps, have a look at page 3 of my thread "lc to lj project" in members plans and projects to see how I mounted mine. The main thing to avoid is the boot area near latch/lock "flexing" (bowing inwards) when mounted. Keep us posted with the great work you are doing! cheers paul
Posted 26 April 2018 - 04:21 PM
Posted 26 April 2018 - 08:21 PM
simply mounted to front and rear bumper mount holes.
Posted 27 April 2018 - 01:27 AM
Posted 27 April 2018 - 04:55 AM
Posted 27 April 2018 - 09:56 AM
Posted 27 April 2018 - 12:16 PM
How was the body on rear when you took the it off?
Did it bend anything?
Posted 27 April 2018 - 12:46 PM
Posted 27 April 2018 - 03:07 PM
no problems, if the mounting brackets are solid they cant go anywhere and so shouldn't the car.
Posted 27 April 2018 - 04:19 PM
Posted 27 April 2018 - 06:59 PM
My LC as it sits currently. Highest point on its side about 1990mm. At the front I used original bar irons bolted to the box section but on the rear I put the forks underneath the beaver and used box section between it and the chassis rails bolted down through the tow bar holes. Very sturdy, didn't like the look of only using the rear bumper mounts and boot latch plate.
I have tried to post pics, sorry if they didn't work. It's the first time iv tried since it all turned to shit and I can't see most pics on here anymore anyway.
That looks nice and solid and easy to do
I'll do the same thing
Thanks mate
Posted 27 April 2018 - 07:25 PM
Posted 28 April 2018 - 07:03 PM
Posted 28 April 2018 - 07:50 PM
Easy to do would be just mount on the bumper mounts.That looks nice and solid and easy to do
Thanks mate
Posted 06 May 2018 - 09:05 PM
Posted 07 May 2018 - 08:49 AM
As the picture above shows I got the car all mounted up.
Just need to remove the diff and front end this weekend and I'll be able to start cleaning it up.
