Split washers for trailing arm bolts. Yes or No
4 replies to this topic
#1 Cook
Cook
  • 1,506 posts
Posted 04 June 2018 - 05:34 PM
Hi,  Just considering using split washers on the trailing arm bolts.  The parts catalogue doesn't show them as being included and wondering if there is a reason for this. Cheers Ron
#2 grumpy xu1
grumpy xu1
  • 2,809 posts
  • Name:Gary
  • Car:lj xu1
Posted 04 June 2018 - 05:55 PM
Hi Ron, don't they have a cone nut on them ? No reason for a split washer with a cone nut as they lock themselves. Single use only though. Gary.
#3 Cook
Cook
  • 1,506 posts
Posted 04 June 2018 - 07:00 PM
I think you are right Gary.  I bought a new set from Rares and just a bit unsure after having trial fitted the diff a few times.  Cheers Ron
#4 TerrA LX
Posted 04 June 2018 - 10:38 PM
No no no no, the the bush fitted to a sleeve which should only be torqued to spec when at ride height.
DO NOT FIT SPRING WASHERS.
#5 Cook
Cook
  • 1,506 posts
Posted 05 June 2018 - 08:53 AM
Thanks for that TerrA LX.
