v6 engine
4 replies to this topic
#1 slack one
slack one
  • 54 posts
  • Name:Gary Carter
  • Car:looking for one
Posted 10 June 2018 - 04:58 PM
Hi to all to the guys that have fitted v6 vr commodore engine in their torana what did you do with the exhaust. I am having problems with the exhaust hitting  on the sway bar this is in a uc torana. It is a standed  exhaust. thanks gary
#2 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 10 June 2018 - 10:48 PM
I haven't fitted a V6 in a Torana, but sounds similar to fitting larger pipes to a V8. You can either fit spacers between the mounting bracket to lower the bar or remove it & fit an after market front mounted bar.
#3 TerrA LX
Posted 11 June 2018 - 09:33 AM
You can change, or space, the sway bar...
#4 slack one
slack one
  • 54 posts
  • Name:Gary Carter
Posted 11 June 2018 - 11:35 AM
Hi guys thanks for the replies. It would cost to much to replace the sway-bar so i will have a go at spacing the bar or bending it. Thanks Gary.
#5 RallyRed
  • 7,843 posts
Posted 11 June 2018 - 04:53 PM
Hi...do you mean bending the sway bar?.
Thinking that might end in tears mate.
Its spring steel...bend it and it will just bend back...heat it up and it wont be a sway bar any more.....just my 2 cents
