Will the diff from an LH torana fit into an LC/ LJ ? .l've been offered a modded 9 inch from an LH and was wondering if it will swap .
Modded 9 inch diff swap from LH to LJ
_NZ XU1_
, Aug 18 2006 08:03 AM
1 reply to this topic
#1 _NZ XU1_
Posted 18 August 2006 - 08:03 AM
#2 _MYLJ_
Posted 18 August 2006 - 10:35 AM
the LH/LX diff is a few inches longer than an LJ diff, so unless the diff is shorter than standard lenth for an lx it will be too long to fit under an LJWill the diff from an LH torana fit into an LC/ LJ ? .l've been offered a modded 9 inch from an LH and was wondering if it will swap .
then there's also the different spring and shock mounts to consider as these are not the same from LJ to LX
