hi guys, i have a second hand set of dragway wheels and two rims look as if they have been changed at some point in their life, i woould like to check them and maybe even pull them down to give them a good clean.
would anybody know the torque setting for the bolts that hold the centre in the rim thanx.
Dragway wheels
, Aug 20 2006 07:12 PM
1 reply to this topic
Posted 20 August 2006 - 07:12 PM
#2 _Yella SLuR_
Posted 20 August 2006 - 09:14 PM
In a word no. Had a new outer put on recently, but had it fitted. Also need to use a sealing compound so air doesn't leak out from the bolts. Ring World of Wheels in Queanbeyan, NSW, they might be happy to share info, or ring Dragway direct in Victoria.
Before taking the centre out, be aware that they need to be pressed out, which in turn will scratch the outers quite deeply. Could be a case of if it ain't really broke, don't fix it.
