New exhaust
#1 _torana06_
Posted 21 August 2006 - 07:20 PM
which will make the highest power?
any suggestions from what you guys have done that you would recommend
and
has anyone got any places to reccomend for building new exhausts.
Living in VIC (eastern side if possible)
Driving LH 4 door 308
Posted 21 August 2006 - 07:30 PM
Single or Dual, which flows better? Depends on what sizes.
What are the specs on your motor? Standard/a bit warm? or wildly worked?
I've seen single 3" systems fitted to quite hot 308s, and twin 2" or 2-1/4" fitted to warm motors. I think the standards was a twin 1-3/4" system or something wasn't it?
A single system can be just as good as a twin system, but you've gotta make sure you've got the right size (unless there's forced induction involved) to get a vaguely correct backpressure for optimum performance.
Also depends on what amount of mufflers/hotdogs/resonators you want to run, have you already got some extractors in mind? and more importantly, a price range?
But yeah, I'd say list some more specs of the motor, I take it you'll want it suitable for street use? so not too loud. etc and some other points to make it a little easier to find what you want.
#3 _torana06_
Posted 21 August 2006 - 07:36 PM
price range is up for what i can get power wise
street noise not the biggest issue for myself as mr plod would have a field day if they caught me anyway
#4 _torana06_
Posted 21 August 2006 - 07:39 PM
Posted 21 August 2006 - 07:43 PM
#6 _LH SL/R 5000_
Posted 21 August 2006 - 08:17 PM
#7 _torana06_
Posted 21 August 2006 - 08:22 PM
great
what was the damage of the whole package
#8 _BoltZ_
Posted 21 August 2006 - 08:42 PM
#9 _torana06_
Posted 21 August 2006 - 08:56 PM
had a look at a couple of sites at these x pipe systems
a two torries look like they do it performancewise
#10 _LH SL/R 5000_
Posted 21 August 2006 - 09:14 PM
#11 _torana06_
Posted 21 August 2006 - 09:27 PM
Posted 22 August 2006 - 01:20 PM
#13 _MAWLER_
Posted 22 August 2006 - 02:09 PM
As for exhuast bloke, mine is shutting up shop in 1 week so can't help you there, must be some other ones around someone could suggest.
Cheers,
#14 _RTS Guy_
Posted 23 August 2006 - 08:53 AM
if fitting Pacemakers pipes to cars with High Energy sumps, when ordering from High Energy just tell them that you will be running Pacemakers and they will modify it for you.Pacemakers are the most commonly used I think.� You just buy an off the shelf set for the LH 308.� They are a Tri Y setup with 1 5/8 primaries I think, which would be about what you are after I'd think.� Only thing is are you running a High Energy sump, if so they won't clear, which is why mine are a custom set.� There was talk of Pacemaker fixing this problem, don't know if the new pipes have hit the market or what tho... Twin 2 1/4 system would be good too, bigger tail pipes are personal and so are the X pipes I reckon, there is evidence for both sides on that one.
Cheers,
Edited by RTS Guy, 23 August 2006 - 08:53 AM.
#15 _LX8VD69_
Posted 23 August 2006 - 10:08 AM
#16 _MAWLER_
Posted 23 August 2006 - 10:20 AM
Peace,
#17 _SSHatch_
Posted 23 August 2006 - 11:34 AM
Simply putting in a balance pipe about level with the end of the gearbox between the two sides to even the sound out. They sound like crap to me without this.
I am lucky in that its actually my Uncle who has been an exahust fitter for 25years thats doing mine.
While on the subject though, I need the rear hanger that bolts to the body just in front of the rear diff on the drivers side for the system.
I have put an "ad" in the wanted section but thought that maybe I might have better luck here!
#18 _torana06_
Posted 23 August 2006 - 05:13 PM
#19 _torana06_
Posted 23 August 2006 - 05:16 PM
that will wake the neibours two suburbs over at idle
#20 _MAWLER_
Posted 23 August 2006 - 05:59 PM
Have had a muffler change since then, don't know what the db is.
#21 _torana06_
Posted 23 August 2006 - 07:39 PM
