HZ brakes on my LH, crap pedal still
#1 _timbotorrie_
Posted 21 August 2006 - 10:16 PM
it has HQ discs HZ alloy calipers front and HQ drums on the back, new master cylinder, rebuilt proportioning valve, have been bled countless times, adjusted right in the drum shoes, tried couple of different pad compunds, tried smaller bore rear wheel cylinders, but the thing just doesnt give any confidence in stopping, it can be scary!
could it be a booster problem? my engine doesnt produce much vacuum,
should i try a different booster as it is the standard type booster?
anyone pleeeeze!!!
#2 _SSHatch_
Posted 21 August 2006 - 10:25 PM
I know that you have already given a fair bit of info but didnt provide any that will aid in diagnosis.
Define "Scary"
Long Pedal?
Soft Pedal?
Locks Rear?
Locks Front?
Hard Pedal with no "Feel"?
Brakes appear to grab suddanly?
Pedal slowly dissappears under use?
Pedal needs to be pumped up on each use?
There are many variables out there. Can you be more specific??
#3 _Herne_
Posted 21 August 2006 - 10:58 PM
After what you have stated and have not I would look at the booster.
Herne
Posted 22 August 2006 - 12:05 AM
And yes describe the actual problem
#5 _timbotorrie_
Posted 22 August 2006 - 08:14 AM
the booster hasnt been touched in the 8 years i have had the car
will get a pic later
Edited by timbotorrie, 22 August 2006 - 08:18 AM.
#6 _Herne_
Posted 22 August 2006 - 10:18 AM
Herne
Posted 22 August 2006 - 06:35 PM
when you first start driving and the pedal feels good then it quickly deteriorates, getting long and soft, the drums are adjusted right up on the rear and boiling the fluid. bleed and reajust the rear drums.
may also be a defective master cylinder.
definatly dont drive it till you sort it.
#8 _timbotorrie_
Posted 22 August 2006 - 07:13 PM
i have been driving it but you wouldnt go racing through any twisty bit of road in it,i just keep a safe distance just in case, i suppose i just want it to feel like my old standard LH which was really good in the brake department(for standard setup)
everything is adjusted right on the rear
just thought it might be something i have missed when doing the conversion, i havent checked pressures at each corner yet though and i may go back to the larger bore wheel cylinders on the back too
from what i have read the standard master should be fine for the disc drum combo as the HQ-HZ used the same master but with different sized holes for the brake lines to screw in
might just try a different booster, buggered if i know!!
#9 _shane__31_
Posted 22 August 2006 - 08:29 PM
#10 _1QUICK LJ_
Posted 22 August 2006 - 08:43 PM
#11 _timbotorrie_
Posted 22 August 2006 - 09:58 PM
its a new master cylinder so it better not have an internal leak!
#12 _MAWLER_
Posted 23 August 2006 - 10:06 AM
Sorry, I don't have anything to add but this is good info. I've now got a few things to check on my car before I get someone to look over it.
Shane, just noticed you're in Montrose, I'm in Lilydale. Don't think I've ever seen your car out and about (pic in avatar), do you drive it much?
Cheers,
#13 _LX8VD69_
Posted 23 August 2006 - 12:09 PM
#14 _timbotorrie_
Posted 23 August 2006 - 07:19 PM
being the smaller booster doesnt help wither, i should get a double diaphragm one i suppose, or as you said add a vacuum tank
Posted 23 August 2006 - 10:43 PM
Larger booster will make it worse as more vaccuum is required
Theres another problem
Posted 23 August 2006 - 11:05 PM
