XU1 callipers
3 replies to this topic
#1 limo
limo
  • 2,672 posts
Posted 21 April 2019 - 09:40 PM
Are the bolts that hold the 2 sections together longer for the XU1 calliper with the spacer than the standard 6 cylinder ones? Can't find anything in the parts catalogue. Also did the XU1 have the spacer where the calliper mounts to stubb axles? Same as HK / HT V8
#2 S pack
  • 15,541 posts
Posted 21 April 2019 - 10:17 PM
The bolts I can't answer at the moment but definitely no HG V8 caliper to stub axle type spacers for the XU1.
#3 S pack
  • 15,541 posts
Posted 22 April 2019 - 03:26 PM
Servicing the LJ this arvo so checked the caliper bolts while she's jacked up.  I've compared the length of a set of std 6cyl caliper bolts to the XU1 caliper, a bit of measuring with the vernier, a bit of addition & subtraction and yes the XU1 caliper bolts are roughly the thickness of the spacer plate longer than the std caliper bolts.
#4 limo
limo
  • 2,672 posts
Posted 22 April 2019 - 04:07 PM
thanks for that
bought a set of spacers years ago from HT V8  and they came with the bolts and didn't have a standard bolt out to compare
now some one wants them so will give him bolts as well
