motor oil
35 replies to this topic
#1 _lawn bowls_
_lawn bowls_
Posted 03 June 2019 - 11:20 PM
what mineral oil is everyone using i need to use a mineral oil that contains zinc for a turbo red 6 the camshaft is a solid 242/242@50 .480 lift 1.5.1 roller rocker ratio,i cant make up my mind on what brand of oil to use,
#2 myss427
myss427
  • 1,636 posts
Posted 04 June 2019 - 08:33 AM
Penrite HP30
#3 LC-GTR-1969
LC-GTR-1969
    Shed tinkerer
  • 1,162 posts
  • Car:Which one?
Posted 04 June 2019 - 09:22 AM
Yes, penrite HPR30, its  good high zinc oil- its a bit thick for my licking but it does the job, is readily available and is specifically designed for classics with flat tappet cams.
#4 hanra
  • 11,035 posts
Posted 04 June 2019 - 10:14 AM
I can even use HPR 30 in my little red cute car. It seems to have many application uses.
#5 Heath
  • 18,403 posts
Posted 04 June 2019 - 10:22 AM
I think most people you ask will use HPR30, including me.
There's also a Nulon 25W-60 'Street and Track' product which has extra zinc & molybdenum in it. Apparently a few of my friends use this in their competition cars.
#6 myss427
myss427
  • 1,636 posts
Posted 04 June 2019 - 11:25 AM
My VE SSV ute started to get lifter noise and the oil pressure was always very low when warm with the Mobil 1, changed the oil to Penrite, picked up lots of pressure and no lifter noise, been in for 5000ks and no issues, was almost going to pull the motor down, but only had 150,000 ks on it.
#7 hanra
  • 11,035 posts
Posted 04 June 2019 - 12:05 PM
I just noticed make this stuff for the little cute cars. Might give this a go, doubt anyone will stock it this farrrrrrrrrrrr north. Might have to be a special order.
https://www.penriteo...0w-50-mineral#/
#8 hanra
  • 11,035 posts
Posted 05 June 2019 - 08:40 AM
I just grabbed some HPR 30 for my black car yesterday. It was $36.99 at Autobarn.
#9 _lawn bowls_
_lawn bowls_
Posted 05 June 2019 - 05:30 PM
it seems like I choose either penrite 25/60 or Lucas 25/60
#10 axistr
axistr
  • 1,226 posts
Posted 06 June 2019 - 09:05 AM
Shell Rimular x 15w40
#11 _Drag lc_
_Drag lc_
Posted 07 June 2019 - 07:56 AM
25/60 may be a little thick if its not loose enough in the bottom end.
#12 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 07 June 2019 - 10:17 AM
Sames here.  My clearances are a little on the loose side so the thicker oil shouldn't be a problem for my motor.
#13 hanra
  • 11,035 posts
Posted 07 June 2019 - 02:06 PM
We need the thicker stuff to combat the ambient temps.
#14 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 07 June 2019 - 02:07 PM
That's right. It's a steamy 13 degrees here at the moment.
#15 hanra
  • 11,035 posts
Posted 07 June 2019 - 03:08 PM
We are in the depths of winter here with that big cold front, only got up to 24.
#16 mugginz
mugginz
  • 325 posts
  • Name:Greg
  • Car:LH Torana
Posted 07 June 2019 - 03:16 PM
That's just not fair
#17 hanra
  • 11,035 posts
Posted 07 June 2019 - 03:45 PM
The rest of the week isnt looking much better with lows of 21 and highs of 26..
#18 308 Sunbird
308 Sunbird
  • 975 posts
  • Name:Stuart
Posted 07 June 2019 - 03:59 PM
Oh you poor bastard Brad :P
#19 CYCO355
CYCO355
  • 152 posts
  • Name:Cameron
  • Car:G PAK and a LH sl, VS Senator, VE SSV sedan
Posted 10 June 2019 - 08:07 PM
HPR 30?
Edited by CYCO355, 10 June 2019 - 08:08 PM.
#20 _74LH_
_74LH_
Posted 12 June 2019 - 07:53 PM
I use Castrol Edge 25w/50 at the recommendation of my engine builder after trying just about everyone else. Seems to work the best with the old red motors in my experience.
I found Penrite oils to be among the worst, at least when I used them for a stint a few years back. Even the HPR30. Seemed too thick for what it was and although it kept the motor quiet, it felt to me like the motor was working harder when on it.
Again, just my experience. I wouldn't say the Castrol Edge makes the world of difference, it's not like I'm picking up hp compared to other oils or anything, but it does the job and that's all I need it to do
#21 _lawn bowls_
_lawn bowls_
Posted 12 June 2019 - 10:50 PM
i have seen that penrite makes a pro 20 oil 20/50 it says trade only dont know why its a mineral oil
#22 _lawn bowls_
_lawn bowls_
Posted 02 July 2019 - 08:52 PM
I have seen driven oil 15/50 mineral oil with zinc and suitable for turbo but expensive like over $100 for a 5 litre bottle
#23 S pack
  • 15,770 posts
Posted 02 July 2019 - 10:04 PM
Never heard of Driven Oils. Obviously they don't let me out enough.
https://www.drivenra...ntional-15w-50/
#24 ozyozyozy
ozyozyozy
  • 953 posts
Posted 02 July 2019 - 10:07 PM
Oils are not oils, the more you read about them the more questions you will have, so many variables to consider and the oil companies dont want to let out all there secrets.
I would look at what is easiest to get your hands on in the area, its great to use these big performance name brands but getting a hold of them is troublesome and if you need a top up cant just duck down to the shop.
I would think hrp 30 would be fine, its a bit thick to be standing on the throttle before oil temp comes up but once oil temp is hot, prob handle heat load better.
A 15w would be a bit nicer.
Penrite should be fine, have heard good things about nulon.
There are synthetic oils with high zinc and additives to suit flat tappet cams, for run in tho would go the mineral.
#25 hanra
  • 11,035 posts
Posted 03 July 2019 - 08:01 AM
I managed to get a hold of 5L of this for my little red cute car.... Bit of a hassle. All the Auto shops here said they could order it in, but they had to order Qty: 4 and that I had to buy all 4.....????
Rapeco was the only help and got one transferred across from Darwin.
You'd think they would make something specifically for Aussie Muscle cars also?
Edited by hanra, 03 July 2019 - 08:04 AM.
