Camtec Cams
Camtec Cams
8 replies to this topic
#1 Kirk
Kirk
  • 840 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 31 October 2019 - 08:40 PM
Any feed back on this cam would be appreciated
Attached File  20191031_010430.jpg   88.71K   9 downloads
#2 I'm a Red Motor fiend
  • 758 posts
  • Name:Adam
  • Car:LJ 4 door, LC GTR
Posted 01 November 2019 - 04:50 AM
Looks like a reasonable hydraulic street cam that should behave well.
But what's your goal? What induction will you have, head, exhaust?
#3 axistr
axistr
  • 1,169 posts
Posted 01 November 2019 - 07:14 AM
Maybe i'm getting a bit old, but that cam has a fair amount of duration for a comfortable street driven car. If it was a solid cam it would be a bit more street friendly. Also the longer the engine stroke the less sensitive they are the cam overlap. A 202 would be slightly better than a 186. I would only expect 10-12 inches of vacuum at idle so tuning at low engine speeds could be a bit of a challenge depending on your choice of induction system. Although you may have enough vacuum for brakes I thing it would defently be on the lower side of the spectrum.
#4 Kirk
Kirk
  • 840 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 01 November 2019 - 11:43 PM
i'll be using tripple SUs HIF6
the head is a  yella terra cast iron 12 port
blue 202 block
10.5 to 1
extractors and a 2 1/2 inch single system
4 speed box
#5 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 02 November 2019 - 05:17 AM
It'll work ok with that combo. :spoton:  :spoton:
#6 axistr
axistr
  • 1,169 posts
Posted 02 November 2019 - 09:14 PM
If the static compression is 10.5 I would normally add a little bit more. A cam that size would only allow for high 7 or very low 8s at idle, there are a few calculators programs on the net that allows you to enter all the known parameters and then recommends a static compression range.
#7 Kirk
Kirk
  • 840 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 04 November 2019 - 03:45 PM
What ratio would you recommend
#8 axistr
axistr
  • 1,169 posts
Posted 04 November 2019 - 07:41 PM
I would generally like to see between 10.8 - 11. 1 with a cam that duration. I like to have a small quench area between the piston and head. I prefer to run .025-035 as this helps reduce the onset of detonation. When building an engine you need to workout every thing first before running out and just buying parts. You need to do correct planning. There is no value in throwing a big cam in that has the potential of 7,500 rpm when the rest of the engine components can only handle 5,500 rpm.
#9 Kirk
Kirk
  • 840 posts
  • Name:Kirk
  • Car:LX SS 253
Posted 04 November 2019 - 09:36 PM
good advice thanks
