Banjo LSD
_LH SL/R 5000_
, Aug 23 2006 05:23 PM
10 replies to this topic
#1 _LH SL/R 5000_
Posted 23 August 2006 - 05:23 PM
How much Hp will a fine spine Banjo LSD handle when not thrashed but driven hard occasionally?
#2 _timbotorrie_
Posted 23 August 2006 - 09:09 PM
i used to give my fine spline bango a hard time with about 120 HP at the wheels, didnt give any troubles.
theres only one way to find out!
Posted 24 August 2006 - 11:43 AM
brocky made it round bathurst with 300+HP
#4 _LH SL/R 5000_
Posted 24 August 2006 - 11:50 AM
Yeah, never thought about that Makka, if the diff can handle Bathurst then it should be ok for me.
Posted 24 August 2006 - 12:44 PM
brocky popped a shitload of axels though...
should be able to new made replacements from most diff places to strengthen it up
#6 _LH SL/R 5000_
Posted 24 August 2006 - 12:54 PM
Or bit the bullet and have some billet axles made. The only problem with that is I'll start blowing the centre instead.
Posted 24 August 2006 - 05:54 PM
Depends on the ratio, tyres (stickiness) and driving style. A full recon with new bearings, and checking the caps for any cracking, as well as regular oil changes will go a long way to making sure it holds together. As with the gearbox, lay off the power until the car is moving, and it will last longer.
Posted 24 August 2006 - 07:02 PM
pretty good diff axle story in latest muscle car mag.relates info on avoiding cracking and breakages in these diffs.
#9 _gtrtorana_
Posted 24 August 2006 - 09:56 PM
I have never blown my banjo LSD and it is course spline. I have completed 30+ passes on the quarter with this diff and it has held up fine. You just have to know how to treat it.
Posted 25 August 2006 - 01:58 AM
Fine spline banjo LSD 512RWHP. The only thing modified on it is a cap reinforcement cradle cause I have had the caps crack on me.
I have abused these diffs with relatively sticky tyres and have never bent axles.
Have tramped the diff at the track and this did break the spider gears but on the street it can take alot of punishment.
Course spline axles on the other hand will break easily.
Open centres break easily also, course or fine.
It is ONLY the fine spline LSD that has any strength.
Dont expext it to survive doing heaps of burnouts/donuts as no cone type diff will.
Straight ahead burnouts where both wheels spin at the same speed ar fine.
#11 _LH SL/R 5000_
Posted 25 August 2006 - 10:04 AM
Jeez, obviously a lot stronger than I thought.
