what should the ring gap be for a boosted holden 6 is going to be 18psi.
ring gap
#1 _lawn bowls_
Posted 10 January 2020 - 11:03 PM
Posted 11 January 2020 - 08:54 AM
Posted 12 January 2020 - 07:22 AM
Three thousands of an inch .003" for every inch of bore size used to be the common gap. I generally like to see an extra one or two thousands for the top ring if subject to extra cylinder temps from boosting. As said above the piston/ring manufacturer should be able to give you good guidelines.
Posted 12 January 2020 - 07:43 AM
blog.wiseco.com/everything-you-need-to-know-about-ring-gap
Bit of a list in this article that should be a good guide to start with.
Edited by EunUCh, 12 January 2020 - 07:43 AM.
#5 _lawn bowls_
Posted 12 January 2020 - 09:17 AM
thanks for the replys i found out for 18psi its 15 thou
Posted 13 January 2020 - 04:14 PM
A bit more hurts nothing, not quite enough will destroy the motor - assume worst case, motor may get hot, may get a bad batch of fuel, whatever.
I ran my turbo 308 with .028/.032" ring gaps.
