LJ Doors
5 replies to this topic
#1 _CanberraTorana_
_CanberraTorana_
Posted 25 August 2006 - 01:35 PM
Hello I am having trouble getting the window winder and door handle off to try retrim the door.
I can't find the clip :huh:
whats the trick to this.
im in the ACT btw
#2 _Yella SLuR_
_Yella SLuR_
Posted 25 August 2006 - 02:37 PM
Buy a window winder remover tool from Supercheap or other auto parts store for $10-$15.
Dunno how the LJ door handles go, but if like the LH, remove the arm rests first.
Edited by Yella SLuR, 25 August 2006 - 02:38 PM.
#3 LOWS2
LOWS2
  • 1,477 posts
Posted 25 August 2006 - 04:21 PM
The clip is there just keep searching, mine were in line with the actual handle/winder, so the tool actually inserts from the end of the handle/winder to push the clip off (hope that makes sense???). Just watch where they end up once the get loose.
Cheers,
Mick
#4 _73LJWhiteSL_
_73LJWhiteSL_
Posted 25 August 2006 - 05:32 PM
I also would recommend a window winder remover... You will have it all off in about 2 minutes with one of them.
As Mick said, insert the tool from the knob end (where you grab the handle) to remove them.
Steve
#5 smeer
smeer
  • 1,526 posts
  • Car:1970 LC 4-door
Posted 25 August 2006 - 06:56 PM
use the tool. It wont pop the clip off so it won't get lost.. and it will also prevent damaging your door trims.
#6 _CanberraTorana_
_CanberraTorana_
Posted 28 August 2006 - 08:21 AM
thanks!
