Over head tune for 6
#1 _gtrtorana_
Posted 27 August 2006 - 08:14 AM
Posted 27 August 2006 - 10:38 AM
#3 _Keithy's_UC_
Posted 27 August 2006 - 11:44 AM
With roller rockers its a bit easier though... You simply tighten them until you can wiggle the rocker but it has no play up or down. I.E. When you wiggle them they dont move up or down at all, only left or right. Once you've fired it up you'll know if you have done it right.
If you want to do it with the motor running, as rodomo says, back them off til they rattle (do one at a time and have a keen ear), then slowly tighten them 1/4 turn at a time, when the motor starts to die on you and does not recover, back it off slightly until the motor is ok again.
With the motor off method make sure you have the motor in compression stroke for each set your doing.
Keith
#4 _gtrtorana_
Posted 27 August 2006 - 07:32 PM
Posted 27 August 2006 - 11:50 PM
#6 _gtrtorana_
Posted 28 August 2006 - 07:40 AM
Posted 28 August 2006 - 04:53 PM
#8 _Keithy's_UC_
Posted 28 August 2006 - 08:20 PM
I'll tell you why i ask this:
202 pushrods are shorter than 186 pushrods. If your head has ever had a shave, it is now a smaller height than it used to be. As you would be (I am assuming) running 186 pushrods, you have now pushed your roller rockers into the studs causing them to bend, and some to snap. I had this happen to me (against the advice of others).
I maybe should have asked this before you asked for advice on tuning roller rockers.
Simple solution - get a set of 202 pushrods now before you keep snapping your studs.
Keith
Posted 28 August 2006 - 09:11 PM
Posted 29 August 2006 - 01:20 AM
#11 _gtrtorana_
Posted 30 August 2006 - 07:37 AM
#12 _Keithy's_UC_
Posted 30 August 2006 - 07:44 AM
Keith
Posted 30 August 2006 - 11:09 AM
#14 _Keithy's_UC_
Posted 30 August 2006 - 12:30 PM
Keith
