ENGINES TOO TIGHT
#1 _crumpledoor_
Posted 27 August 2006 - 07:57 PM
Posted 27 August 2006 - 08:08 PM
#3 _devilsadvocate_
Posted 27 August 2006 - 08:19 PM
#4 _JNR_ATE_
Posted 27 August 2006 - 08:38 PM
Are the bearings oversized that u fitted, i remember my rope seal made mine alot tighter once fitted but i could still roll it over.
Does it roll either way, could one of the rings some how jammed up.
JNR_ATE
#5 _torana_
Posted 27 August 2006 - 08:50 PM
Can you put a socket and breaker bar on the harmonic balancer and spin the crank?
cheers julian
#6 _Toranamuk_
Posted 27 August 2006 - 10:02 PM
Did you check directions of the caps in relation to the bearing notches ?
What tensions ?? 70ftlb mains & 25ftlb for rods (bot with a drop of oil on the threads & under the bolt/nut heads).
Did you trial fit the crank & all tensioned up before removing it to fit the rear main ?
How much bearing clearance, end float etc etc.
Probly safer to remove it now & at least drop the sump & have a look, the bearings are probly trying to rip themselves apart.
Posted 27 August 2006 - 11:05 PM
Did you clean the ring grooves correctly? The same thing happened to me years ago - turns out the ring grooves weren't cleaned properly.
Bazza
Posted 28 August 2006 - 05:15 PM
#9 _LX8VD69_
Posted 28 August 2006 - 05:21 PM
#10 _rorym_
Posted 28 August 2006 - 05:45 PM
Edited by rorym, 28 August 2006 - 05:46 PM.
#11 _Keithy's_UC_
Posted 28 August 2006 - 08:36 PM
If it's a manual and you painted the flywheel, get under and pry the clutch off the flywheel... I did this (why didnt my car go anywhere, and not go into gear while switched on)?!?! I pulled the engine out again to find that the clutch was the prob and pulled it off the flywheel, put the show back together and drove it that night...
If it wont turn over, please tell me you used engine rebuild grease/lubricant on all your bearings and what not. Plenty of oil in the bores prior to putting the pistons in, and i hope you turned the motor by hand a few times before you put the head and sump on...
If it's been sitting for a while it could just be a case of 'turn me over once a week sir'... put it in second, roll down hill. The motor will turn over...
Keith
#12 _crumpledoor_
Posted 28 August 2006 - 08:38 PM
#13 _rorym_
Posted 28 August 2006 - 09:04 PM
#14 _LX8VD69_
Posted 28 August 2006 - 09:28 PM
im sorry rory i couldnt resist but i dont know what girls you were hanging around when you were 15 coz whan i was 15 all the girls i knew were like buckets of warm waterwas the tightest thing this side of a 15 y.o.!
#15 _crumpledoor_
Posted 28 August 2006 - 09:33 PM
#16 _jimjet61_
Posted 28 August 2006 - 09:34 PM
Posted 28 August 2006 - 09:36 PM
#18 _crumpledoor_
Posted 28 August 2006 - 09:37 PM
#19 _draglc_
Posted 28 August 2006 - 09:45 PM
i didnt think this conversation could get anymore sus!im sorry rory i couldnt resist but i dont know what girls you were hanging around when you were 15 coz whan i was 15 all the girls i knew were like buckets of warm waterwas the tightest thing this side of a 15 y.o.!
i was wrong!
A1
#20 _SSL31_
Posted 28 August 2006 - 11:08 PM
#21
Posted 29 August 2006 - 01:21 PM
#22 _crumpledoor_
Posted 02 September 2006 - 07:44 PM
#23 _[BOTTLEDUP]_
Posted 02 September 2006 - 09:23 PM
#24 _JNR_ATE_
Posted 02 September 2006 - 09:45 PM
JNR_ATE
#25 _1QUICK LJ_
Posted 02 September 2006 - 10:05 PM
