GTR or S model?
12 replies to this topic
#1 _LHoon_
_LHoon_
Posted 28 August 2006 - 01:53 PM
Hi guys,
I know you can spot a GTR from the VIN number, but I'm just wondering whether its possible to find out any details of an LJ purely from the chassis number, rather than relying on ID tags.
Is there database somewhere which lists chassis numbers and the model / vehicle options?
Thanks in advance!
#2 _gtr-xu1_
_gtr-xu1_
Posted 28 August 2006 - 02:06 PM
nope PSN (VIN) is what you need or the BIP (body id plate) to get model info
#3 _LHoon_
_LHoon_
Posted 28 August 2006 - 02:23 PM
The car only has one ID plate at the moment. It has the ID plate which says:
LJ TORANA SEDAN 2 DOOR
5/73 BLJ#####B <-- chassis number
So surely ID plates can be stolen / swapped around. Logic would mean that there should be a record of genuine GTRs based on the chassis number, the only number which is actually part of the car. The other numbers are just pop-rivetted on!
#4 _gtr-xu1_
_gtr-xu1_
Posted 28 August 2006 - 02:37 PM
logic is one thing and what holden did in the early days is another.
you may find a number (written in marker) under the ADR tag that will tell you a missing tag info
#5 _LHoon_
_LHoon_
Posted 28 August 2006 - 02:53 PM
OK. I will check that, but I don't like my chances.
Are there any tell tale signs with the actual car body I can look out for then?
#6 WhiteA9XS
WhiteA9XS
  • 1,646 posts
  • Name:Shaun
  • Car:LJ LX
Posted 28 August 2006 - 03:18 PM
GTR has over the S model , bodywise
1/ fluted guards , look for factory spot welds where guards are welded to body.
S model doesnt have these unless they have been added on later
2/ chrome strip from front of car to rear of car along the side of body , look for rivet holes or where they could have been on a S model
otherwise bodies are identical
#7 makka
makka
    A m��se once bit my sister
  • 3,559 posts
  • Name:Cohen
Posted 28 August 2006 - 04:35 PM
look at the C pillar from the inside and see if you can see where the holes from the "S" badge have been welded up. I know the LC's had them, I dont know about LJ's
#8 _doublin gtr_
_doublin gtr_
Posted 28 August 2006 - 05:05 PM
lj never had them.
but i belive the S had a extra spare wheel bracket on the boot floor sombody with a S maybe able to conferm this
:tease:
#9 _LHoon_
_LHoon_
Posted 28 August 2006 - 06:28 PM
Ok thanks guys! I'll check for all of those things.
#10 _gtrtorana_
_gtrtorana_
Posted 30 August 2006 - 07:43 AM
They have the extra spare wheel bracket in boot.
#11 warrenm
warrenm
  • 2,107 posts
  • Car:1972 LJ Torana
Posted 30 August 2006 - 08:06 AM
Anyone have a picture of the extra spare wheel bracket?
#12 _JBird_
_JBird_
Posted 30 August 2006 - 10:22 AM
http://www.gmh-toran...opic=3665&st=15
just on a side note, in the last pic of the march 17th gtr xu1, in the top left hand corner just above the fuel tank theres a brass nut. Apparently only LJ XU1s and not 100% but maybe GTRs had those too. :spoton:
#13 Pop's-SS
Pop's-SS
    Pops
  • 4,963 posts
  • Name:Barry
Posted 30 August 2006 - 10:19 PM
G'day LHoon
The usual spots have been mentioned but what about the suspension.
The LC GTR has Ferguson Tractor stiffness but I'm not sure about the LJ GTR.
I would presume that the S model would have normal suspension if not modified therefore if you bounced each guard up and down and then let go it should go up and then settle down about halfway of the vertical travel.
If it keeps on bouncing for a little while then the shockies are stuffed under that guard.
Mine bounce bugger all because of the stiff suspension AND yes it rides like a Ferguson Tractor AND, I wouldn't have it any other way.
Hope this helps, regards .................. Barry
